April 07, 2025, 12:09:54 am *
Author Topic: Not enough space on playback drive  (Read 8430 times)
KnB
« on: May 28, 2015, 09:37:52 am »
Hi Peter
Have one record I'm getting this message on.
Sondre Bratland, den blå glede.
Does not matter witch track, attended or unattended.
Any idea?
RAMdrive b: 2MB
« Reply #1 on: May 28, 2015, 10:26:24 am »
RAMdrive b: 2MB
Well, that is enough for 10-20 seconds of music, so I suppose you mean 2GB. Happy
It looks like this blå (last character) can be the culprit ? Easy enough to try - just change that å into a in the album name (do this in the Original Location (so not in a Gallery) and try again (but played from the Original Location).
If this helps, change it back and show me the complete path if possible. I think you can do that by means of selecting the album path in Explorer and next click in the URL area of Explorer (mind you, not Internet Explorer). Then there the complete path shows and you can make a screen copy of that.
KnB
« Reply #2 on: May 28, 2015, 10:47:31 am »
Thanks Peter,
Yes, it was the letter å
Path:
Z:MusikkPop og rockSSondre BratlandDen Blå Gleda - 2005
« Reply #3 on: June 12, 2015, 04:05:26 pm »
Kjell Narve,
I have just tried this, and it normally works ?
This is 2.02 now but nothing changed since 2.00. However, regarding this it sure did since 1.186 ...
« Reply #4 on: June 12, 2015, 04:20:26 pm »
I had this problem also with Imdisk.
Make sure you format in FAT32 and not the one NTSC??
And make sure that the path is not the same as your music HDD. Somehow that was a problem here.
KnB
« Reply #5 on: June 12, 2015, 09:56:16 pm »
Hi!
Nothing changed with W10, with or without imdisk.
Page created in 0.013 seconds with 19 queries.
