April 09, 2025, 12:11:32 am *
Author Topic: Not enough memory.  (Read 9806 times)
noaa
« on: May 27, 2015, 07:13:50 pm »
Hi Peter!
I Have a question about xxhigend, the program plays fine, but signs often pops up saying there's Not enough memory. My computer has 16 GB RAM, so there should be enough of it.
Any idea what it might be?
Best regards Nils Ove.
« Reply #1 on: May 28, 2015, 08:13:07 am »
Hey Nils Ove,
I think the message you talk about goes something like "Memory is low", is that right ? If so, then this is related to your Virtual Memory setting. This is in :
- Explorer
- Rightclick MyComputer / This PC
- Properties
- Advanced System settings
- Advanced tab
- The topmost Settings button
- Advanced tab
- Bottom section "Virtual memory".
heat
That should be at minimum the size of your memory, thus 16GB (or more) in your case.
but
I myself have this Virtual Memory at 0 (thus switched off) and never have any problems with it. This is also the advice. So if you now receive these messages, it is a bit strange.
Do you use coverart ? if Yes, how large are your coverart files ? They should be 500K - 1000K (1M) and not e.g. 30M which can easily happen with some "wrong" scanning.
Are we talking about the same message anyway ? (hence what is the message *exactly* ?).
« Reply #2 on: May 28, 2015, 12:23:03 pm »
Peter, to set the virtual memory to zero I assume you uncheck the "Automatically Manage Paging File Size for all Drives" at the top of the last screen you pointed to above and, then, check "No Paging File?"
« Reply #3 on: May 28, 2015, 12:40:34 pm »
yes
noaa
« Reply #4 on: May 29, 2015, 05:38:03 pm »
Hey Peter!
I've tried what you said I should do and it has worked well so far. And it looks like it helped to set Virtual Memory to zero, there haven't been any signs popping up so far.
Regards Nils Ove
« Reply #5 on: May 29, 2015, 06:12:34 pm »
Ah, great. Thank you for the feedback, Nils Ove.
Have a nice weekend,
noaa
« Reply #6 on: May 29, 2015, 06:25:57 pm »
Thank you , you get to have a good weekend even
regards Nils Ove Happy
