November 23, 2024, 06:04:31 am *
Author Topic: 2.00a: cover art disappears when volume is changed  (Read 5640 times)
« on: May 17, 2015, 03:26:20 pm »
In unattended, cover art disappears for currently playing track when Alt U is used to change the volume. The cover art reappears when the next track in a playlist starts.
« Reply #1 on: May 17, 2015, 03:39:35 pm »
In that case I think that the Coverart you see at first is not the right one to begin with (and Windows 8 assumed).
Try to do this :
Start XXHighEnd - Press Stop. Leave it be.
In your XX folder (think about RAMDisk as well) there's a Wallpaper.bmp file; delete that.
Now officially change the Wallpaper (change it into something else to be sure). So rightclick on Desktop - etc.
Now start playback.
I think it will be fine now. But let me know ...
« Reply #2 on: May 17, 2015, 08:12:30 pm »
Did the above procedure you described but no luck: changing volume causes the cover art to disappear for the track that is playing; it reappears at the start of the next track in the playlist.
