April 07, 2025, 01:41:44 am *
Author Topic: 1.03 Driver Question  (Read 7837 times)
« on: May 16, 2015, 03:35:03 pm »
Edit May 13, 2015 : BUT, the 2.00-a version (which is the actual one for download now) contains a Driver103.tss file. If this file is renamed to Driver103.tst you can use the 1.03 Driver version. Notice that if your file extensions do not show you may see "Driver103" only (while it is really named Driver103.tss).
Does the quote above mean that once you've renamed the tss file to tst you do not need the 1.04 driver to play material other than 44.1 after installing 2.00-a? I ask because I thought you only needed the 1.04 version if you wanted to play material other than 44.1 based.
« Reply #1 on: May 16, 2015, 04:47:36 pm »
I read it 5 times but I see two the same things, unless the word "based" means something special for the second half.
It is fairly simple : If you want to avoid installing the 1.04 Driver then make sure you have 2.00-a and rename that file.
I'm sure I did not understand the question / pose ...
« Reply #2 on: May 17, 2015, 01:48:11 pm »
- When you use XXHighEnd 2.00 you will *need* this new Driver (1.04) or otherwise you can only play 44.1 based material ( 44.1, 88.2, 176.4, 352.8 ).
So my question was/is if you rename the 1.03 driver to tst --using 2.00a-- will 48KHz material still play 10% too slow?
« Reply #3 on: May 17, 2015, 02:04:04 pm »
No of course not. Happy
« Reply #4 on: May 17, 2015, 02:26:34 pm »
Thanks. So wouldn't it be simpler to delete all references to the 1.04 driver from the release notes since the 1.04 driver isn't needed anymore?  Happy
Page created in 0.01 seconds with 19 queries.
