April 07, 2025, 02:51:48 am *
Author Topic: Remote link to server  (Read 22017 times)
« Reply #15 on: May 16, 2015, 11:11:29 am »
Robert - What is worse is that I have been working on the very same issue (but someone else) in a dozen of emails and could not solve it. But that other person of course never tells about where he installed it and I assume it *can* not be in Program Files because it is protected against that. scratching
But seeing yours (TeamViewer) and within 6 seconds I saw the issue and 60 seconds later it was all solved.
esimms86
« Reply #16 on: May 16, 2015, 07:29:52 pm »
OK Peter, so what's the fix for that?
Esau
2010 mac mini running Windows 7 Professional N 64bit *SP1* and XXHE on SSD in Boot camp mode, mac os x Snow Leopard with Audirvana Plus also on SSD, music on  separate 2 Tb firewire La Cie HD / 8 Gb RAM/ Engine#4 *Adaptive Mode* / Q1/2/3/4/5 = *30*/0/0/0/0 (Dev.Buffer = *4096*) / ClockRes = *15ms* / Straight Contiguous / SFS = 170 / not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3/ *Minimize OS = On*  / 24/768 Phasure/Is Phasure NOS1/ NOS1 async USB DAC, Driver v1.0.2 -> Marantz PM KI Pearl amplifier ->Gallo Strada/Gallo TR3 subwoofer
« Reply #17 on: May 17, 2015, 09:07:38 am »
Esau - just don't install in Program Files but in a self created root (and sub) folder.
Btw the problem has been solved in the program (but I won't make a new version/patch of that) and it is really ridiculous :
Envision that "Program files" can be anything in another language. This is created by Windows and thus in your own language. At least that is what can be expected for such folder names and for sure others do. I have English so I can't even check the difference. Anyway there's an official command that presents the normal English name to the programmer. And while using that command would be the best way to do it (e.g. check whether you try to install XXHighEnd in "Program Files") it reports wrongly. So for fun you could look in your root on c: and you will see \Program Files\ and \Program Files (x86)\. The latter is about 64 bit stuff if the OS is 64 bits and the NOT 64 bit stuff would be in there. Think back door solutions from MS here ...
So when you put XXHighEnd in \Program Files\ (notice that XXHighEnd is 32 Bits) then this command reports that it is in \Program Files (x86)\.  Well, this is not "Program Files" so I (XXHighEnd) don't reject it. But still other things go wrong and this is known from the start.
\Program Files\ is for Windows-installed programs and not to dunk in stuff ourselves.
This is a perfect example of how things can not be tested some times. So if I work in English then I don't even bother to check the code because it should be "Program Files" anyway, but would I have done that check back at the time - I used a 32 bits OS (which we all did back in the days) then it still would have been OK because no \Program Files (x86)\ existed (exists) in the 32 bits OS.
The bug is not mine but is Bill Gate's who blindly reports the program to be in the 32 bits folder because it *is* a 32 bits program. The bug is Bill Gate's another time because he allows us to dunk programs in \Program Files\ which does not work out outside an official install. The bug is mine because I too allowed to "install" in program files, but this was just bad testing. Well, sort of, because back at the time no "(x86)" existed.
Ehm ...
Software ...
