April 06, 2025, 05:21:24 am *
Author Topic: Remote link to server  (Read 21997 times)
Robert
« on: May 12, 2015, 10:50:13 am »
I'm just about to launch with a Samsung tablet into the XXhighend remote  world. Can I not link directly with the main computer without using another computer inbetween. I have your USb dongles but never used. I'm not going for the ultimate in sound at this stage.
Not trying new XXhighend yet. Have a new server coming.
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #1 on: May 12, 2015, 12:02:11 pm »
Hi Robert,
Depending on the situation it can be correct that you need that other PC (like I do it). So you are using WiFi now ? that is OK.
What could not be OK all the way is that you are doing this with the old version. I mean, things changed (for what's available in MinOS) and I can't check the old situation any more. But if you get it running, that's fine of course.
Robert
« Reply #2 on: May 12, 2015, 12:10:15 pm »
No not using WiFi, in fact not using at all just bought on Monday. I downloaded your new version but it didn't load. Does it only work from remote from start? Perhaps my I3 laptop is not up to it? think perhaps I should wait for new I7 server. Probably need to read your instructions and digest.
Oppo 205 UDP Dac
« Reply #3 on: May 12, 2015, 01:07:13 pm »
Didn't load ? It just should. Can you be more specific about what you see happening ?
No Remote as such is in order at first.
No real instructions to read either. Just start XXHighEnd.exe ...
scratching
Robert
« Reply #4 on: May 13, 2015, 11:30:10 pm »
I downloaded Xx2 unzipped into new folder within Xxhighend folder.
Clicked on xx.exe and it started installing. I clicked run on all install boxes except the very last security warning box, which nothing happened when I clicked run. I clicked out and then warning XXengine 3 did not start.
When I loaded Xx186a it acted as if it had been a new download.
Tried this several times. Should I delete the old Xx186a version then try to run new install?
Robert
Oppo 205 UDP Dac
Robert
« Reply #5 on: May 14, 2015, 08:06:51 am »
I got my new server today so forget laptop issues.
I will start from scratch with Xxhighend 2.00 on this new machine Saturday. Brand new so will need licenses. I presume does this mean two required?
Oppo 205 UDP Dac
« Reply #6 on: May 14, 2015, 10:05:53 am »
Only one (new) license is required.
Robert
« Reply #7 on: May 15, 2015, 07:06:42 am »
Hi Peter no luck with new server loading Xxhighend same problem as laptop.
Gets to Open file security warning(Change wp.exe) I press run button and nothing happens.
When I click away a screen comes up with Initialization failed at Phase 121.
Robert
Oppo 205 UDP Dac
« Reply #8 on: May 15, 2015, 10:24:57 am »
Hi Robert,
Can it be the case that you use bitdefender ? I think I heard similar from someone else. However, that started for him when I installed 1.186-a and I think you already used that. So next guess could be that you activated bitdefender after you had 1.186-a running and that made things all right.
So if all my guesses are correct then the remedie could be to deactivate bit defender, install 2.00-a again and see whether that helps.
Btw, no antivirus etc. is good for sound !
Let me know ...
Robert
« Reply #9 on: May 15, 2015, 12:05:55 pm »
No anti virus what so ever.
Oppo 205 UDP Dac
Robert
« Reply #10 on: May 15, 2015, 12:11:40 pm »
Gosh can't get the former XXhighend 8a version.
Oppo 205 UDP Dac
« Reply #11 on: May 15, 2015, 12:23:44 pm »
Why not ?
« Reply #12 on: May 15, 2015, 12:27:32 pm »
Robert, I sent you an email ...
« Reply #13 on: May 16, 2015, 08:47:09 am »
Robert
The reason for this to happen is that XXHighEnd is not allowed to be installed in c:\Program Files\ and it was.
There is a check for that in the program but apparantly that check fails. Sorry for that !
Robert
« Reply #14 on: May 16, 2015, 11:05:22 am »
Gosh I'm so happy you solved the problem. Funny the basic things you forget. Well my laptop has the same issue but works fine.
So much going on in our lives easy to forget the basics!!!!!!
Oppo 205 UDP Dac
