April 05, 2025, 02:58:07 pm *
Author Topic: >10 tracks still not allowed to get activation code in 2.00  (Read 16651 times)
Arjan
« on: May 11, 2015, 10:41:51 pm »
Maybe I do something wrong. But after a lot of tracks and restarts of XXHE I am still not allowed to get an Activation Code for 2.00.
regards, Arjan
March, 2024 (2.11)
« Reply #1 on: May 11, 2015, 10:48:48 pm »
Thank you Arjan,
That doesn't seem to be correct (obviously).
scratching
Arjan
« Reply #2 on: May 11, 2015, 11:09:03 pm »
I setup ramdisk already and all other settings that could be done without activation. Tried multiple tracks with and without ramdisk.
Tomorrow I will try a clean startup again. First without ramdisk, and try activation first.
Regards, Arjan
March, 2024 (2.11)
Arjan
« Reply #3 on: May 12, 2015, 07:49:19 pm »
Solved. Just installed again, no fancy settings, now activated within minutes.
regards, Arjan
March, 2024 (2.11)
« Reply #4 on: May 12, 2015, 08:29:17 pm »
Thank you Arjan !
But, ... you suggested/implied I think that I already said (Release Notes) that this should be done outside of the RAMDisk. But did I ? I merely think I forgot ...
But it would be very true that first the RAMDisk must be "not used". Not even sure though ...
Any insight ?
Thank you again,
Arjan
« Reply #5 on: May 12, 2015, 08:37:48 pm »
That might be the reason. I used ramdisk Yesterday.
By the way, the SQ is really good! Full and detailed sound.
Regards, Arjan
March, 2024 (2.11)
« Reply #6 on: May 13, 2015, 04:53:40 am »
I ran through the same problem as Arjan. I did use the ramdisk, but not to execute XXHighEnd in it, just for the transfer of the music in the playdrive.
I will reinstall XXHE tomorrow and report.
« Reply #7 on: May 13, 2015, 12:43:40 pm »
Anyone else having this problem ?
It seems something is not right but I need to find "similarities". So please announce yourselves !
Thanks ...
« Reply #8 on: May 13, 2015, 01:25:33 pm »
regards, Arjan
Hi Arjan,
Can you tell ...
What exactly means "installed again" ? I mean, you could have started with formatting your disk (haha) up to delete your latest XX 2.00 folder and create a new one and nothing else (and then it worked) ... and anything in between.
Arjan
« Reply #9 on: May 13, 2015, 05:05:28 pm »
Hi peter,
Just deleted the XXdata and XXhighend2.00 folder from my C: drive.
Copied XXHighend 2.00 in again and started the XXHighend.exe. Did the minimum to run some tracks and activated.
The first time I just copied the XXhighend2.00 in started the .exe but also did all the settings including RamDisk. Before running tracks and try to activate. But that was not possible.
regards, Arjan
March, 2024 (2.11)
« Reply #10 on: May 13, 2015, 05:17:08 pm »
Thank you Arjan.
The problem has been found by now, so a patch will be up soon.
« Reply #11 on: May 13, 2015, 05:45:02 pm »
All,
For some (for sure not all) it could happen that the Activation wouldn't work (as described in this topic). This is now solved in the new 2.00-a version, available in the original topic :
XXHighEnd Model 2.00 - New Filters & Extended Remote Control.
You can deleted the contents of your old XX-2.00 folder and unzip the new 2.00-a over it. Or make a new folder (all not important).
Apologies for the inconvenience !
PS: If, for some reason outside this issue, you download this new 2.00-a version and use that, you will not be Activated. But the procedure for such a thing is known (money is returned right away).
« Reply #12 on: May 14, 2015, 12:10:35 pm »
I downloaded the 200a version and is activated.
« Reply #13 on: May 14, 2015, 12:47:44 pm »
Alain, great. Thanks.
