April 05, 2025, 11:30:27 am *
Author Topic: Some Infos About DSD  (Read 8122 times)
« on: April 30, 2015, 05:33:31 pm »
http://www.positive-feedback.com/Issue78/dsd.htm
« Reply #1 on: May 01, 2015, 02:09:11 pm »
Here's another interesting article. They offer identical copies of DSD and PCM files for comparison. Anyone here able to give the files a listen?
http://www.ayre.com/insights_dsdvspcm.htm
« Reply #2 on: May 01, 2015, 02:26:05 pm »
I didn't look into that article because I think I know it;
Take that with some grains of salt because it is apples with oranges comparison. It always is (but more so here for a reason I forgot) and that is the whole issue (and subject of what Joachim posted) : only when the file is "native" (not converted) and only when you play it through a non-converting D/A converter, a comparison has merits. And still not, because the D/A convertes should be the same as well. Quite hard for prerequisites ...
So the same counts for PCM (which most often is recorded by SDM (is actually DSD) means.
Page created in 0.029 seconds with 17 queries.
