April 17, 2025, 11:37:37 am *
Author Topic: Custom filter: Message "Playback stopped ....data did not arrive in time"  (Read 7294 times)
« on: April 07, 2015, 11:16:44 pm »
After a stable situation of the system (no XXHE stops during playback) i switched from Arc Predict to Custom. After one track XXHE stops without user interference and shows a message "Playback stopped because the data did not arrive in time". When i switched back to Arc Predict it works without a message.
Playback is unattended
See logfiles
Last weekend I did the same tests and try to increment sfs to 60 no effect. I'm using Ramdisk.
Any suggestions?
Best Regards Johan
* X3-20150407-221647.log (687.32 KB - downloaded 526 times.)
* X3PB-20150407-221647.log (43.22 KB - downloaded 525 times.)
* XX-20150407-212950.log (49.74 KB - downloaded 514 times.)
* XX-20150407-222210.log (2.19 KB - downloaded 532 times.)
« Reply #1 on: April 08, 2015, 08:21:14 am »
Johan,
This is 1.186-i and this is an unsupported version for it's "hidden" new functionalities.
All I can say is that my settings for the NOS1a should work, an SFS of 4 (or maybe 2) being the most crucial for the Custom Filter to not let happen what you just described.
Anyway, a known anomaly and already so before it was put up.
But solved in the next version.
« Reply #2 on: April 08, 2015, 01:04:41 pm »
.........an SFS of 4 (or maybe 2) being the most crucial.......
i have changed the sfs to 2 and its working ok.
I didn't realize it was so critical. Mostly of the time when you have troubles you need to increment sfs.
Thanks.
Johan
