November 23, 2024, 09:55:06 pm *
Author Topic: W8 Volume change ticks  (Read 6091 times)
« on: March 16, 2015, 12:17:03 pm »
I've started to get two quick ticks when volume actually changes after an  Alt/u or d command in unattended. Not really a problem, but it has never happened before and over the past two days it happens every time I change the volume.
« Reply #1 on: March 16, 2015, 01:05:08 pm »
Brian, then your SFS is too low. IIRC from of 2 this does not happen.
« Reply #2 on: March 16, 2015, 01:31:06 pm »
Thanks Peter. It's interesting that I've been using W8 a couple of months now and this just started. I'll see if changeing the SFS helps but I don't want to change SQ. If SQ is effected I can live with these ticks cause they never happen during playback.
« Reply #3 on: March 16, 2015, 03:07:06 pm »
Reboot ?
