« Reply #135 on: March 20, 2015, 04:44:53 pm » |
Meanwhile ... I don't know how I do it, and possibly I can earn some $$ with it in a circus or so, but : The first round I ordered 20m of cable. When all which was ordered for was produced, I was told that I did my calculations very well because 7cm of the cable was left (earlier on I told 20cm, but it was 7cm really). Well done. But I didn't calculate anything against the orders; just thought it would be fine. This afternoon I again was thrown such a compliment, this time about the outer dielectric : I ordered 40 meters before round 1 was produced. Now round two is finished and one piece of ~60cm and one piece of ~50cm is left. Thank you again, but it turned out automatically like this. But actually I was lucky again (what could I have told you, who ordered and payed). This also concludes round two unless someone can use a very short USB cable.  Thank you all. Peter
Stanray
« Reply #136 on: March 20, 2015, 04:55:19 pm » |
I see mine
« Reply #137 on: March 20, 2015, 04:59:47 pm » |
Careful, one is shorter than yours.
Stanray
« Reply #138 on: March 20, 2015, 05:22:18 pm » |
9th from below?
« Reply #139 on: March 20, 2015, 05:43:00 pm » |
That's what I estimated, looking at the photo and the length data on the screen here. So LOL, I just walked downstairs to check and Yes. Label says "Stanley, 0,70". Unless that's not you, all should be fine.  PS: Sorry we didn't label you Mr K. haha
Stanray
« Reply #140 on: March 20, 2015, 06:13:40 pm » |
So I won the prize of the day
« Reply #141 on: March 20, 2015, 06:22:16 pm » |
To be honest I thought of :
Next one ? But no prizes to win !
But I didn't do it. So yes Stanley, you definitely won the prize of the day.
« Reply #142 on: March 20, 2015, 07:33:42 pm » |
1 next to the paper roll?
« Reply #143 on: March 20, 2015, 07:40:44 pm » |
Yes Gerard, but that is not fair. You have the smallest ... Or shortest. Something to be not so proud of ?
« Reply #144 on: March 20, 2015, 07:48:15 pm » |
Yes Gerard, but that is not fair. You have the smallest ... Or shortest. Something to be not so proud of ?  Yeh yeh yeh.... Had to ask
« Reply #145 on: March 20, 2015, 08:17:02 pm » |
Didn't you intend to say "with the ground wire not connected the balanced signal floats" ?
Yes! Salut, Coen
« Reply #146 on: March 22, 2015, 11:08:53 am » |
All,
Day before yesterday, when I was trying the Clairixa without power for its "working" in the first place (leading to the plus wire not connected at both ends), I thought to listen to it when I was at it anyway.
First impression during a brief 2 track listen during the day time : More air. Different anyway for sure.
Second impression during normal listening in the evening : way more bass. What I also noticed happening is that right away many tracks went into my "Demo" folder for the Orelo MKII speaker (should be bass oriented). None of that happened since I use the Clairixa with the notice that at some stage it becomes difficult to find more "super bass" tracks after say a year trying to find them. So, a clear indication to me (read : quite objectively).
Later, when I was outside to sip a cigar (nasty habbit) it came to me that the same thing was happening to me now, decribed by scroobius (Paul) : the house shook. Strange experience because it felt like military practicing (explosions) because I was outside. Inside I did not notice that really. Outside I did, and since it was on the rythm of the music - it was the music (but I'm still scratching my head because so "abnormal" and observable outside only (door closed).
I focused explicitly on that bass for the "is it right ?" thing. I never found it to be wrong as such, and it was only that I in my mind it was a continuous "but why and how ?!".
Then, later again (think of a total span of 4-5 hours or so) I started to notice the "separation" between what the basses were doing and what the remainder of the music did. Disconnected or something. Now the gag of the bass started to disappear and instead it started to be too profound. Annoying. Under way (but this was a bit more from the start I'd say) I also noticed rolled off highs. However, since I am also trying the new filters, I put this aside (stupidly).
Then the day was over and a new day started (yesterday). This time, right away, it annoyed. What was in my mind from the day before now became profound in another way : no music. So this time I played "Demo" stuff from my Orelo MKII folder and what got in there over the past year because of sheer "happiness" now was no joy at all. I tried for 30 minutes and several tracks, and no-one did it. But also : too bass heavy. Overwhelming the highs *if* they didn't roll off in the first place.
After these 30 minutes I had to know and used the cable with power again (it is the same cable). I started with a track of which I knew I put it in that Orelo MKII Gallery the day before, just to see whether I would (have) put it in with the normally "powered" cable. Well, I still recognized the track for its bass and maybe I would have put it in that Gallery anyway, but there wasn't much chance to observe it, because the machines turned into music again and I now liked it for *that*.
And so it happened again : When something is wrong with USB there is more bass and less highs. I already told about it more often - it is just a sheer measure, but needs quite some experience to utilize it like a measure (and I can thus still waste a day on it). This time I explicitly obeserved the bass to be "better". But this seems to be at the lowest end only (more individual vibrations at say 40Hz and under). Otherwise it's a too dark sound. What I did not notice before - but this is because of the lacking experience with Windows 8 and this speaker and possibly much more (NOS1a, Blaxius, Clairixa itself, 1.186-a software) is that no MUSIC wanted to play. So the robot thing from W8 when it wasn't right.
All in other words : quite interesting at first, but a pitfall as usual.
The remainder of yesterday's evening all was fine. Nothing to watch for, nothing to jump out. Just lovely.
Regards, Peter
« Reply #147 on: March 22, 2015, 12:22:15 pm » |
Hey Peter, thanks for taking the time to sort out the virtues, or lack thereof, of a "data only" Clairixa. Now I won't have to mess around with the same effort!
« Reply #148 on: March 22, 2015, 12:51:43 pm » |
Oh, you can try Brian. Maybe it's just me or my situation. But I think in the end it is very similar to what others reported. But with different cables of course.
Regards, Peter
« Reply #149 on: March 22, 2015, 01:16:56 pm » |
Regards, Peter
Ufffff, I was sweating thinking I had to cancel the power in the Clairixa  Juan
