« Reply #120 on: March 14, 2015, 05:53:36 pm » |
... And I don't know what freakin' company I am dealing with, but the cable still hasn't been shipped. Still it was ordered for last Monday.
Now if someone could give me a few good lessons on how to deal with Americans ... If I'd only write out the email conversations to you from this week. And then to think this is a simple repeat order.
Unbelievable.
« Reply #121 on: March 14, 2015, 06:22:52 pm » |
But here you have one example only, as per an email at 10pm my time last night and after that the guys started celebrating some weekend : Getting ready to ship and the shipping clerk is telling me I did not write down the expiration date to your credit card
Can you kindly give it to me again. And then to think that the first round I was not asked for the security number of the credit card. So in that case *that* lacked. No, I don't know how to deal with this. Yes, take the time for it ... (which means the customer of course - You)
Tubeamp
« Reply #122 on: March 18, 2015, 02:51:28 pm » |
I heard good feedback about your USB cable. Can I order one? I need 75 cm. And what will it cost?
Bye, Hans The Netherlands.
« Reply #123 on: March 18, 2015, 03:48:43 pm » |
Hi there Hans,
Yes, you are just in time to order for this round. Cost will be 192,50.
I sent you an email as well. Kind regards, Peter
« Reply #124 on: March 18, 2015, 04:45:27 pm » |
So ... cable finally arrived today. Everybody got his invoice and if all is right the lot will ship upcoming Monday. Shipping time is 1 or 2 days, depending on where you live ...
Thank you all, Peter
« Reply #125 on: March 19, 2015, 08:33:35 pm » |
For Alan and maybe others ...
Extension cable can also be constructed (hence produced) and works ...
« Reply #126 on: March 20, 2015, 10:52:26 am » |
USB tweakers ...
We just tried a Clairixa without the power wires. That does NOT work. That is, not for the NOS1a. Still the NOS1a does not use the power. But maybe there's more to this than I figured in advance;
With the ground connected it does work.
Now, without sorting it all out at the technical level I would say that the differential setup of USB can allow to let it work without explicit ground, because differential creates its own ground. This is not entirely true per se, which is why I said can. Now :
I know some of you have tested the USB connection by leaving out "the power". But what did you actually do ? So for instance, you can tape the plus wire (in the connector) alone, but you can also tape the ground wire. Virtually we over here did both and that does not work. Tape only the plus wire does work ... Or if you have/had a cable without the power connection in there, was that also without the plus wire ?
Please let me know your experiences, with the notice that very far theoretically the NOS1a can behave differently here than the normal NOS1. This is about the isolation in the NOS1a ...
Thanks ! Peter
« Reply #127 on: March 20, 2015, 12:30:52 pm » |
A data-only USB cable is a cable that only contains the + and the - data leads. It does not contain the +5V power lead. lt SHOULD contain the ground lead. The above quote is from the YFS site regarding their data only cable. So they only "tape" the + power lead but not the ground. I use the YFS V4 cable.For me, it is significantly better than the standard $1 cable, though I'm anticipating a change to the Clairixa.
« Reply #128 on: March 20, 2015, 12:55:22 pm » |
Hey Brian .. thanks !!
Are you quickly able to measure whether the ground lead is connected ? If you (quickly) say yes then I will quicly tell you which "pads" in the connectors to measure. Get your wife because it is hard to do this on your own (multi meter measuring Ohm resistance).
« Reply #129 on: March 20, 2015, 01:01:57 pm » |
Btw, I said "quickly" because you might be heading for work ... If you have the A connector and put it on the table so you see the (golden) pads in the connector (they point towards you). The left most is the ground. If you have the B connector and put it on the table with the flat side under. The left bottom is the ground. And if you are in your car and a queue already - bad luck.
« Reply #130 on: March 20, 2015, 01:06:59 pm » |
Haven't left for work yet, but I lent my volt meter to my friend Rick! I should be able to get it back tonight or tomorrow. Will let you know. Maybe Joachim could do it faster since he has a YFS cable too?
« Reply #131 on: March 20, 2015, 01:16:44 pm » |
Thank you Brian. No worries.
So ...
Joachimmmmmmmmmm ? That is, if you have one without power connection in there.
But I guess it is clear already ? Ground should always be connected. Still that feels like a disappointment. I mean, out of all we don't want the ground to be connected. Or ?
« Reply #132 on: March 20, 2015, 01:50:18 pm » |
YES !!!I measured the 4 (ground), the ground is connected.
« Reply #133 on: March 20, 2015, 04:05:54 pm » |
Hi Peter, I just made the cables with only the red (power) wire DISconnected. It occurred to me that with the ground wire the balanced signal floats and as such can float above the logic level 1 or below 0, so no real data are transported. Just like the YFS I had on the visit. The "other ground" complicates the matter, I refer to the screen. In datatransportland the screen must be connected to quiet earth to behave properly. Otherwise you are better off without it (capacitive couplings of the wires to the screen). USB cables' screens are connected to the chassis of the two devices. Any grounding current for the balanced USB signal has to go though that path.... regards, Coen
« Reply #134 on: March 20, 2015, 04:11:03 pm » |
Hey Coen - many thanks. It occurred to me that with the ground wire the balanced signal floats Didn't you intend to say "with the ground wire not connected the balanced signal floats" ?
