November 23, 2024, 03:37:17 am *
Author Topic: Only non-ASIO drivers can be used  (Read 9081 times)
« on: May 31, 2007, 01:42:37 pm »
Note that XXHighEnd does not make use of ASIO drivers.
For those currently using the USB.DE (USB.COM) USB ASIO driver, in order to let XXHighEnd work over USB, that driver must be uninstalled;
When the DAC stays connected, reboot the PC, and then the MS USB Audio (legacy) Driver will self-install.
As far as I know there is no way of keeping the USB ASIO driver installed (e.g. on another USB port), and making use of the USB Audio Driver at the same time.
It is very easy to reinstall the USB ASIO driver though.
Page created in 0.104 seconds with 19 queries.
