April 06, 2025, 08:22:38 pm *
Pages: 1 2 3 4 [5] 6 7  All
Author Topic: Confirmed : PC Damping  (Read 128484 times)
« Reply #60 on: February 06, 2015, 05:34:01 pm »
Ok Joachim, now this  good is for you.
May I help? Here you go:
Continuing with Ikea products (I think we deserve some discount on the next purchase) here is the possible egg holder: http://www.ikea.com/gb/en/catalog/products/60209474/
And the steel ball bearing: http://www.ebay.com/itm/10mm-Diameter-Grade-100-Hardened-AISI-420-Stainless-Steel-Ball-Bearings-/131408860399?pt=LH_DefaultDomain_0&var=&hash=item1e989414ef
 Wink
Hi Juan,
thanx for the links. Happy
We remember Peters "water bath" support/platform for the NOS1, and the idea to place an 18" inner tube under the IKEA board, when possible, is not so bad.
« Reply #61 on: February 06, 2015, 05:38:23 pm »
We remember Peters "water bath" support/platform for the NOS1, and the idea to place an 18" inner tube under the IKEA board is not so bad.
I have a couple of bikes bicycles Wink, so while the warm weather arrives I can give them a better use   yes
« Reply #62 on: February 06, 2015, 05:52:28 pm »
I have a couple of bikes, so while the warm weather arrives I can give them a better use   yes
 Happy Ha, Ha Happy
are you talking about motorcycles  Happy Happy or bicycles Happy?
« Reply #63 on: February 06, 2015, 05:59:46 pm »
Here is something similar to Peters idea- floating platforms -
found here:
http://www.barrydiamentaudio.com/vibration.htm
Hi Joachim,
I think Barry Diament's base for that is this :
http://www.townshendaudio.com/hi-fi-home-cinema-equipment-vibration-isolation/hi-fi-home-cinema-vibration-isolation-equipment-stand-rack/
« Reply #64 on: February 06, 2015, 06:30:27 pm »
Oho,
nice racks. There is more behind vibrations, horizontal and vertical forces have to be eleminated.
Thanx Peter. I found the link on CA, where a thread about the IKEA boards is running too.
« Reply #65 on: February 07, 2015, 11:30:06 am »
FYI and FWIW :
Instead of taking out the board I gave it a last chance by putting footers under it - the same as normally under my NOS1a (and which are still there). It is only that I positioned the three of them "opposite" to those under the NOS1a (so where under a NOS1a leg are two, under the board is one, and the other way around).
And now I am fed up with 4 days of being totally annoyed with the sound.
bye
« Reply #66 on: February 08, 2015, 10:46:39 am »
All back to normal yesterday evening. heat
I think I souldn't be doing these things because it only brings annoyance.
Indirectly it also shows like this :
When all is OK, one after the other track goes into the Demo Gallery. Or find some new albums for Nice Stuff. But nothing of either the past few days; only selection of albums of which you hope they can play all the way instead of (also annoyingly) looking for a next after the first track already.
Arjan
« Reply #67 on: February 08, 2015, 01:32:24 pm »
I also tried the ikea board, off course. It is easy to test.
Only the board did something, not sure all for the better. But the barrydiamond idea with the bicycle tyre - ikea board - bearing really did it. Most stunning improvement it the depth of the soundstage. Unbelievable nice now. Will try the same with my amplifiers this week.
For the bearings I use magic dreams of omicron. The tyre is a 14" innertube.
Regards, Arjan
March, 2024 (2.11)
« Reply #68 on: February 08, 2015, 06:19:47 pm »
Regards, Arjan
  yes , when a water bath works ......., and now the suspension is adjustable!
« Reply #69 on: February 08, 2015, 06:39:28 pm »
Yes ... very nice.
Small downside : So you *will* adjust it. And watch out for flat tyres ! (or blown ones Happy)
Anyway, I could hear when I needed to add water (vaporized too much).
Thank you for sharing Arjan.
vrao
« Reply #70 on: February 10, 2015, 06:03:54 am »
Coincidentally
NEW METHODS FOR QUANTIFYING SONIC PERFORMANCE: PART TWO
Part Two: How to Use Subjective and Objective Methods to Quantify System Performance
http://www.theabsolutesound.com/articles/new-methods-for-quantifying-sonic-performance-part-two/
I've not read the whole article as yet, and can't comment ....
« Reply #71 on: February 11, 2015, 07:36:17 pm »
After some time without the possibility to listen music I returned today to my home and placed the NOS1a in the bamboo boards. The first thing I noticed was that the sound was not as smooth as the previous time when I first listened the Blaxius. Now the sound seems to be more like the real thing, less euphonic. However I´m not sure if the sound now is less smooth due to the boards. What I´m sure is that when the phase is changed (the NOS1a came with the outputs changed) the sound perceived is smoother than with the correct phase. That same effect happened also other times before when I changed the outputs of a dac. It may be that one is accustomed to hearing the music in a way and with the phase changed the effect surprises.
I have to play however with the boards and footers. Take a look to the picture to see how I placed the boards and footers. Two bamboo boards on top of other Ikea board. The footers are the ones Peter advised with holes, I put two feet in each place, one in top of the other. The sound now is at least as good as the best moments I can remember. Can it be any better? Sure, allways can be better but I could easily live forever with this sound.... I mean, If I were not as I am  Wink
« Reply #72 on: February 12, 2015, 01:28:56 am »
Hi Juan,
My question will sound silly, but the holes that you drilled, they go all the way through the piece right ?
I am curious to hear about the differences that you may hear depending how you turn them. Do you align the holes in the same direction for all of them ?
Tore
« Reply #73 on: February 12, 2015, 08:28:46 am »
I`m using Sonic Design damping feet under my NOS1 and amp
http://www.sonicdesign.se/sdfeet.html
Tore
« Reply #74 on: February 12, 2015, 09:53:02 am »
Hi Alain, I have not make changes with the feet so far. I placed two feet in place of one just for intuition and placed the holes 90º turned from the one in the base to the upper one, if you look at carefully the previous picture you can see the different position of the holes. What I can say is that the sound this way is great with a really wide soundstage, good and defined bass and very realistic voices with an almost intimidating presence. If it is due to the Blaxius or the bamboo boards or both I really don´t know. I´ll try in the next days some variants to see if I can hear any difference.
Tore hi, those footers at least are cheap. I take the question that made me Alain and I sent it to you. Any difference?
