November 24, 2024, 08:01:28 am *
Author Topic: HDCD problem 1.186-i  (Read 9716 times)
Tore
« on: January 03, 2015, 02:46:09 pm »
Hi Peter!
!.186-i is working fine but it is one problem: HDCD CD`s
Often they will not start playing. If they start playing the next CD without HDCD is not starting. Then i have to close xxhighend and start it again
I hope you can solve that problem in the next xxhighend version
Tore
« Reply #1 on: January 03, 2015, 04:09:28 pm »
Hi Tore, I've had the exact same problem with HDCDs for ages now. I've commented on the problem quite a few times here, but I guess Peter has other priorities. This is a shame because virtually all HDCDs sound superb (among the best sounding CDs I have).
The workaround for now is to convert your 16/44.1 HDCD rips to 24/44.1 files. You can re-rip with dBpoweramp and engage HDCD dsp, or just use dBpoweramp's Music Converter to convert your current rips to 24/44.1 files.
HTH.
« Reply #2 on: January 03, 2015, 04:55:29 pm »
Hi Tore,
HDCD is just difficult to have right for all situations. And what I recall is that in 1.186-i a new bug for it was introduced.
But already solved here for the next version.
PS: Notice that the real problems occur when HDCD and not-HDCD are in the same folder. So that is not allowed and it will never be.
hvdh
« Reply #3 on: February 21, 2015, 08:40:58 pm »
Hi Guys,
I've had some issues with HDCD, so did some (about 1 minute's worth) of research.
Does anyone on this forum have any experience with hdcd.exe (just do a google search..)
I presume this could solve all HDCD issues, once the hdcd encoded files are converted to 24 bit files?
Henk
Win10 14393.0 / music on LAN /  / Q1/-/3/4/5 = 30/-/1/1/1 / xQ1 = 40 / Dev.Buffer = 4096 / ClockRes = 15ms / Memory = Straight Contiguous / Not Include Garbage Collect / SFS = 20.19  (max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/  / UnAttended (Just Start) / Always Copy to XX Drive / Stop Desktop-Remaining-WASAPI-W10 Services / Keep LAN - Persist / WallPaper On / OSD On / Running Time Off / Minimize OS / XTweaks : Balanced Load = 42 / Nervous Rate = 100 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable / Arc Predict -> Clairixa USB 0.80 meter -> 24/768 Phasure NOS1a DAC With B'ass and Phisolator -> BAlanced interlink -> Apogee Grand loudspeakers, using STAX dma-x2 (midrange ribbon) / Krell FPB600C (bass ribbon)
If it flies, Don't ground it!
« Reply #4 on: February 21, 2015, 09:36:59 pm »
Hi there Henk - will help, but it's really the issue of XXHighEnd and not being able to play "mixed" Playlists (HDCD and not HDCD encoded).
« Reply #5 on: February 22, 2015, 09:38:54 am »
Yes, exactly that is what also happens here.
hvdh
« Reply #6 on: February 22, 2015, 05:28:34 pm »
That was exactly what I was hinting at... If you convert all your hdcd files to 24 bit files, you will not have any hdcd files anymore, so the problem is solved....
Or am I missing something here???
Henk
« Reply #7 on: February 22, 2015, 05:34:18 pm »
Hi Henk,
No, correct !
Page created in 0.162 seconds with 19 queries.
