November 24, 2024, 01:53:24 am *
Author Topic: AIFF files problem  (Read 5746 times)
fralippo
« on: December 23, 2014, 08:17:15 pm »
I've a folder with a album in AIFF format, 10 tracks. If you open it (in Windows) you only see these files, with .AIFF extension.
When you open it in XXhe 20 tracks are shown. The first 10 begins with "._" followed by file name. These can't be plaied.
Everything is ok with following 10 tracks.
Is this behaviour known? What's wrong?
Thanks
« Reply #1 on: December 23, 2014, 08:43:43 pm »
Fralippo,
Hidden files from the Mac. So make sure you can see Hidden Files and delete them.
N.b.: You can search for them (top right in Exlorer, from the main folder concerned) and delete all what's in the resulting list. This will be coverart as well, but all will be in your folders for real as well. But check a few to be certain.
