April 01, 2025, 12:39:14 am *
Author Topic: A new PC for XXHighEnd...  (Read 17262 times)
fralippo
« on: December 08, 2014, 06:29:55 pm »
Would you suggest a Intel i3 CPU or would a i5 be a better choice?
Maybe there is no need for higher "power".
Motherboard would be a quality one, such a entry level Asus Z or H97, with a good PSU in the Eur 100 range.
Suggestions? Thanks!
« Reply #1 on: December 08, 2014, 11:06:55 pm »
Hi
My i5 playes the tunes most of the time, but not all the time. Also not sure if its the PSU, motherboard and/or processor that's holding back SQ.
Now I would be wise and buy a more performant processor. The more cache and cores, the better -it seems-. Graphics processing by the CPU chip (aka the IGP) is not relevant and its use should be avoided by installing a cheap graphics card. i7 standard would be my absolute minimum. I'm contemplating on upgrading to extreme series in 2015.
regards, Coen
« Reply #2 on: December 09, 2014, 08:47:02 am »
There always is. This is because "we" are always working against the limits. And sadly it is so that these limits always show the better SQ.
So trust me : My SQ will be better because I have the more powerful PC. I just can dial in "more" from XXHighEnd ...
PS: This counts for everyone not owning a NOS1a.
« Reply #3 on: December 09, 2014, 01:58:48 pm »
When I will have my NOS1 with an "a" at the end of it, it will mean that I can use a less powerful PC to play my music ?
« Reply #4 on: December 09, 2014, 06:53:47 pm »
Hi Alain,
To some degree, Yes. But it is a dangerous assumption. So about the "XXHighEnd limits" etc. - not needed anymore. But running everything cool etc. and the famous 430MHz thing ... that is something else.
So I wouldn't count on it.
fralippo
« Reply #5 on: December 09, 2014, 08:14:07 pm »
Interesting Peter. But how does this requirement for higher power relates to heavy clock slow down? It looks as you use 500MHz, or less on CPU.
« Reply #6 on: December 10, 2014, 12:55:48 pm »
Hard to explain in a few words when you didn't follow this all. But think over-dimensioning ... OK, now you still won't understand.
Today's better (or best) CPU's are not only faster for frequency, but they contain fast memory caches, more memory lanes and a lot more. These parts won't be divided by 10 when the frequency goes down by a factor of 10. Frequency (speed) is important, but it is by far the least important (for what we do with it). So notice :
When this is optimized like I did it for Windows 8 (see sig for Windows 8 (not the NOS1a link)) then the PC uses 48 Watts during playback of 32/750600. And that with a CPU usage of virtually 0%. Still e.g. a laptop with the normal CPU frequency (say 10 times higher) may use 30% of CPU and it takes ages to load a track in the mean time.
It just can't be compared ...
« Reply #7 on: December 10, 2014, 03:06:36 pm »
The main point since **NOS1a** is, what PC configuration produces the best SQ, and everything else (components) follows this judgement.
A) PC system with an internal PS
or
B) PC system with an external**linear** PS
