April 01, 2025, 12:50:12 am *
Pages: 1 2 3 [4]  All
Author Topic: Network storage  (Read 142182 times)
« Reply #45 on: March 04, 2016, 07:58:25 pm »
Do not make your own terms up here, because the first who does not understand is you yourself.
Thanks.. will use common terms!  sorry
The question was basically also if I can remotely control the Audio PC through a direct connection between that PC and the Music Server PC (my main PC should be used for that). I know I can using the network (the switch) but apparently it works the same.
Now set up the RDP connection from the tablet to that screen. That is really all ...
Thanks, that's clear now...  yes
Remotely control one PC using it remotely to control another one using its own RDC connection... mmm, let's see if my network card needs a crosslink cable or not (not so new one!).
« Reply #46 on: March 04, 2016, 08:18:25 pm »
Hi Bert,
I have 2 network cards on my Music server PC.
- The wired one is connected to the Audio PC
- The second one is wireless (USB connected), accessing my router (internet).
This way, I can use my Music to access internet, do whatever I need to do, and I can also access the Audio PC with the wired connection (through RDC).
And as Anthony (aka acg) mentioned, there is no need for a special network cable to link the Music server to the Audio PC, since the moden network cards are intelligent enough to invert one side (output > input) so a "cross feed" (or "cross link" cable) is now obsolete. But you can of course use a cross feed cable if you wish Happy
« Reply #47 on: March 04, 2016, 08:31:35 pm »
Thanks Alain,
For a brief moment I could connect directly through a normal CAT5 but after logging off from the Music Server PC (my main PC) there is no way to connect anymore though that cable directly...
The before used way to connect still works so nothing is lost.
Somehow there is something weird going on which I need to tackle first to be able to login after a reboot as well. Next XX will need to find my files on the Music Server PC...
I do know now that I only need the extra network card to make things work one day. It will then be similar to your setup Alain.
« Reply #48 on: March 05, 2016, 09:52:00 am »
I do need a crosslink cable/adapter to make a connection...
Found an old PCI LAN card which acts similar (both 1G) to the internal LAN connection on the PC.
For the moment I can use another more simple approach and that is selecting a list, press play and unplug the LAN from the audio PC.
Nothing beats any other connection...  Wink
« Reply #49 on: March 05, 2016, 11:26:20 am »
Bert,
And then be out of control ?
nea
Not to interfere and I realize you don't announce this as a problem, but I don't get it ...
I'd say you already had this working :
Music Server PC -> RDC -> Audio PC.
Mind the "Server" part which means that your music was already there and thus your Audio PC already obtained it from there.
If I am wrong with this then OK. But if not, you now must have done something which should not have been done ?
But never mind; I just noticed it.
« Reply #50 on: March 05, 2016, 03:41:22 pm »
Yes, with the Audio PC connected to the main house network (switch) but not directly with a LAN cable from Audio PC to Music Server PC.
This connection can't be made (needs a crossover) and when done the next step might be a problem to get access to the NAS through the Music Server PC
« Reply #51 on: May 11, 2016, 09:10:20 pm »
My XX PC Playback computer is connected via network cable to the wi fi router and the music server is also connected via network cable to the wi fi router. Obviously that is not the recommended configuration as shown here:
http://www.phasure.com/index.php?topic=3060.msg33165#msg33165
Having read the thread it seems Mani has better SQ with the recommended configuration. Now normally I would just try it but in my case it is a real pain in the a**s to do it (floor boards need lifting etc etc). So I do not want to make the change unless it really is justified in sound quality terms. I will of course make the change if justified but I was wondering what the experience of others is in respect of SQ. Is it really recommended for better SQ?
Arjan
« Reply #52 on: May 11, 2016, 10:04:41 pm »
Hi Paul,
To my ears it was even a bigger upgrade for SQ then I had expected. So yes you will hear it. Can you not first place the pc's more close to each other for testing? That was what I did first.
Regards, Arjan
March, 2024 (2.11)
« Reply #53 on: May 12, 2016, 08:29:23 am »
Hi Arjan,
Thanks for the feedback. It is not very easy to setup the PC's close to each other even temporarily it is probably easier to run temporary network cabling. I will have a look over the next couple of days to see what is the easiest way to do it.
Robert
« Reply #54 on: July 03, 2016, 10:04:43 pm »
I've finally setup my music via Lan using an old computer.
I'm having problems with keeping the network connection open from the old computer. Rebooting music server did solve the connection issue yesterday but I have had to reboot it again today. I don't turn off this computer but it does go into sleep mode after 3 hours.
I have loaded W10 into the music computer and it is not connected to the internet. Both computers are connected directly together as per diagram at start of this topic.
What network software setup should I use to keep the connection open? I used Microsoft network settings. Is it necessary to use homegroups?
Ram OS works fine when it sees the music server so all is good here I think.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #55 on: July 04, 2016, 07:59:23 am »
Hi there Robert,
No. And my advice would be to not attempt that, as it is highly confusing (I never understood it and usually can't get it to work either).
Your problem will be that the server falls asleep, but I think you recognized that already. So what to do about that ?
Of course I don't know what PC you mean by that ... I assume "Audio PC". So :
Maybe a bit depending on the OS you have running in the Music Server PC, the preventing from falling asleep can be tedious. IIRC Vista was a drag about it; Windows 7 (only RTM ?) the same. Anyway, this should be in power settings.
Not only the main screen, but also inside (Advanced Settings I think it is named) there's things about sleeping and hibernating and what not. Shut that all off (not the disks and USB etc. - so only the "system" things).
NOTICE : Do the very same in the Audio PC (but I'd say that I did so in the RAM OS Disk already).
To make all more robust, do this :
Open a command prompt by right-clicking on the command prompt in the start menu, and then choosing Run as Administrator. Once you’re there, type in the following command:
powercfg -h off [enter]
(exit [enter] leaves the command prompt)
Now the system has no means to sleep because it can't store the memory anywhere (this is about shutting off hibernation).
This too has been done in the RAM OS Disk, if all is right.
Now all should stay awake ...
N.b.: Monitors can still set to be switched off after xx minutes, as you wish.
Robert
« Reply #56 on: July 06, 2016, 06:19:21 am »
       Yes that works the music server which is W10 was going to sleep. All good now thanks.
Robert
Oppo 205 UDP Dac
« Reply #57 on: July 06, 2016, 10:35:24 am »
