KnB
« on: December 03, 2014, 11:49:13 pm » |
Hi, Planning to have all music stored on a music server. Need advice how to arrange this best possible way. Hardware, software and setup. - will use iPad for remote control. - high storage capacity. Min 20 TB. - back up. - Lan between music server and xxhighend pc.
Phasure system: XXHighEnd stealth Mack III LPS PC, Xeon scalable 14/28 - Lush^2 Blaxius^2 - NOS1a/G3 75B Dac - Orelo mkII speaker
Win 10 14393 - XX 2.11 - min OS - RAM drive - Music on LAN - Adaptive 4096 - Allow format change - Core 3/5, low, Real time - Clock res 15ms XTweaks 52,10,1,0,1 - Boost at xxhighend startup - SFS 10.19/10.19 SC - Incl garbage - Copy to xx - Always clear proxy - Use remote desktop Use touch facility - Stop desktop/remaining/wasapi services - Keep LAN - Use remote desktop - OSD text - Show as wallpaper - Q1,3,4,5,xQ1;14,1,1,1,10 Prosessor set to 20 cores - Driver 1.04; USB buffer 16ms
KnB
« Reply #1 on: December 04, 2014, 12:05:50 pm » |
See planned setup.
Can I use a NAS or should I use a server with a higher capacity? Software required to make this work? Will use team viewer to control the music server and xxhighend PC. As I understand this is how Peter have it arranged.(?)
Any input/ recommendation is very much appreciated.
« Reply #2 on: December 04, 2014, 05:52:54 pm » |
Yes, all fine Kjell Narve. It is only that I wouldn't use TeamViewer for Remote Control. But do notice that RDC for IOS exists ... So I would use that (never tried it, but heard good things about it). http://technet.microsoft.com/en-us/library/dn473013.aspxAnd oh, a NAS is maybe unnecessary complicated and it will usually do more than what you want from it. So if you have the choice of using a normal PC for it, ... that is what I would do (and do btw). Regards, Peter
« Reply #3 on: December 04, 2014, 06:00:10 pm » |
Forgot :
I have a 6TB harddisk in use since a couple of months; works great. So 3 of those and ...
KnB
« Reply #4 on: December 04, 2014, 07:35:29 pm » |
Will try a normal pc with 6tb disk, and using remote desktop. Now, how do I control the xxhighend pc using Lan conn.? Thanks!
« Reply #5 on: December 04, 2014, 07:52:35 pm » |
KnB
« Reply #6 on: December 04, 2014, 09:02:23 pm » |
OK, So I should continue with remote desktop directly to the XXhighend pc. Then I can connect the LAN from the xxpc and the music server directly to the router (save me a network card with 2 ethernet connection on the music server)
« Reply #7 on: December 05, 2014, 08:18:47 am » |
Ho. That is not what you have drawn in that schematic. The schematic is the way to do it *and* the way how I use it. It will also be the fastest means of connection. So connect XXHE PC to the music server. Music server is in the LAN and in the LAN there's a WiFi access point (can be the router but just as well a dedicated one (access point).
Notice that now the XXHE PC is not connected to the Internet.
« Reply #8 on: December 05, 2014, 12:15:52 pm » |
I was planning to build also a similar network so it could be also a big help for me.
What I´m going to use is a laptop as music server with a USB hub with several hhd with music. This laptop is connected to the Music Pc and to the router.
My questions are:
Following the same schematic as KnB, can I use a laptop connected to a USB hub with some hhd with music as a music server?
What software must be in the laptop in case I don´t want to use a remote tablet? Do I have to install TeamViewer in this case in the laptop? Any advantage if I don´t use a remote tablet (in SQ I mean?
KnB
« Reply #9 on: December 05, 2014, 02:00:10 pm » |
Thanks Peter,
- 2 LAN connection on the music server, will add a new card for this. - Remote desktop connection to the Music server. - Remote control of the XXpc from music server - how should this be arranged?
« Reply #10 on: December 05, 2014, 04:45:16 pm » |
- Remote desktop connection to the Music server. Yep. After you "first" let control the Music Server the Audio (XXHE) PC. So you have a cascaded RDC connection. Tablet-RCD -> Music-Server -> Music Server-RCD -> Audio PC.  Peter
« Reply #11 on: December 05, 2014, 04:49:24 pm » |
Following the same schematic as KnB, can I use a laptop connected to a USB hub with some hhd with music as a music server? Hi Juan, Yes. But you can expect the disks to be too slow to not bother you. Only if the laptop has USB3 it could be OK. What software must be in the laptop in case I don´t want to use a remote tablet? See previous post.  Any advantage if I don´t use a remote tablet (in SQ I mean? No, because the last part in the chain is the same and only that part counts. Peter
KnB
« Reply #12 on: January 11, 2015, 03:31:24 pm » |
All done now  Music on LAN. Put together a new server same as this one: http://www.computeraudiophile.com/content/610-computer-audiophile-pocket-server-c-p-s-v4-cortes/Supermicro motherboard have two LAN and a IPMI port. Flashed SAS controller to IT, do not need RAID Work very nice, time it takes to load music is not an issue at all. Using Microsoft remote desktop between music server and XX pc, RDP between tablet and music server did not work... so far. I do not understand why. Just using teamviewer for this until I have figured it out. This works OK, but think it will be better using Microsoft RDC. Very happy with the result.
« Reply #13 on: January 11, 2015, 03:57:05 pm » |
Well, now you must help me ...
You mention two LAN ports but I do not see a relation to that (you don't mention something either, explicitly).
So how is this going to "help out" ?
Regards, Peter
PS: If that is supposed to be the PC holding the music, yes, then I can see it. I mean, my PC holding the music also has two LAN ports and I use them both for this. Well, sort of, because one connects to the router hence Internet and internal Home network, and the other to the Audio PC. Could do without the Internet / Home connection and in that case still one LAN port is sufficient.
KnB
« Reply #14 on: January 11, 2015, 04:08:24 pm » |
Two lan as I need Internet to the server  One crossed Ethernet cable between server and xxpc. Server will be used for ripping music and other tasks, And one nice feature is the IPMI were I can manage the server including switching it on and of remotely, not needed but nice.
