November 23, 2024, 04:36:10 pm *
Author Topic: Set State ( Pause ) error on pin  (Read 8349 times)
« on: December 02, 2014, 10:17:14 am »
Lately I try to play in XXHE and get the error 'Set State (Pause) on pin'.
No playing is possible.
Is there something I can do to prevent this?
Gerard (A)
« Reply #1 on: December 02, 2014, 10:26:30 am »
Hi Gerard,
I encountered this frequently. It is usually an USB problem. Switch NOS off and on or try another USB cable first.
Another symptom: It looks like the NOS is in its driver control panel, but you can't really change something.
regards, Coen
« Reply #2 on: December 02, 2014, 10:34:38 am »
Hi Coen,
Thanks for your quick reply.
But it looks like I'm in big sh*t!
I have no NOS...
Could be my Terratec phase 24FW is giving the problem then.
( I used to use a m2tech hiface to my DIY-dac but after installing Win 8.1 update 1 it did not work anymore. I still had a terratech phase 24FW, that did not work too, but after restart of pc it works.. unhappy.
Then I connected digital out of the phase24 to my DAC and it works. But now XXHE doesn't seem to like it)
And BTW does anybody know why I need to restart the PC to get some sound?
« Reply #3 on: December 02, 2014, 02:32:32 pm »
Hi Gerard,
I'm afraid I can't be of much help ...
When this happens, the DAC was recognized but the streaming isn't "running" so to speak. So something must go wrong with the initialisation of the interface (can be driver level, can be hardware level).
Try an older driver ?
Maybe the buffer size can also cause this. So try to vary a bit with the Device Buffer Size (and let Q1 be at 14 or so (and xQ1 at 1) so you just double/halve the Buffer Size with the Device Buffer Size setting).
Hope this helps but I wonder ...
« Reply #4 on: December 02, 2014, 03:37:28 pm »
Thanks!
It did not help but it helped!
Setting Q1 to 14 was not possible it was 18 but wanted to go to 13 or 16 but not 14. I tried to reset the Phase24FW but no help.
So out of frustration tried the hiface again and surprise, surprise it worked again and XXHE plays better then ever.
(Also got a new belt for my recordplayer today so my day is good again! Wink)
« Reply #5 on: December 02, 2014, 05:02:52 pm »
Haha
When you first click the small button of such a slider, you can next use left-/righ-arrow for the small steps.
