November 22, 2024, 09:40:43 am *
Pages: 1 [2] 3 4  All
Author Topic: XXHighEnd settings for the NOS1a  (Read 67331 times)
« Reply #15 on: January 27, 2015, 04:23:17 pm »
Hi Brian,
And this is all with Windows 7?
Regards Johan
« Reply #16 on: January 27, 2015, 04:23:55 pm »
Yes-W7.
hvdh
« Reply #17 on: January 27, 2015, 05:09:21 pm »
Me Too
Win10 14393.0 / music on LAN /  / Q1/-/3/4/5 = 30/-/1/1/1 / xQ1 = 40 / Dev.Buffer = 4096 / ClockRes = 15ms / Memory = Straight Contiguous / Not Include Garbage Collect / SFS = 20.19  (max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/  / UnAttended (Just Start) / Always Copy to XX Drive / Stop Desktop-Remaining-WASAPI-W10 Services / Keep LAN - Persist / WallPaper On / OSD On / Running Time Off / Minimize OS / XTweaks : Balanced Load = 42 / Nervous Rate = 100 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable / Arc Predict -> Clairixa USB 0.80 meter -> 24/768 Phasure NOS1a DAC With B'ass and Phisolator -> BAlanced interlink -> Apogee Grand loudspeakers, using STAX dma-x2 (midrange ribbon) / Krell FPB600C (bass ribbon)
If it flies, Don't ground it!
« Reply #18 on: January 27, 2015, 05:15:28 pm »
Brian : Although I have never tried exactly *that*, I can imagine that W7 is more prone to SQ differences by these means in the first place. But I didn't know it (from the "a" I mean). So, interesting.
« Reply #19 on: January 27, 2015, 05:24:38 pm »
I never use the internet from this machine, but obviously it is connected to the router, and thus only protected by the firewall.
Depends on what we call "obviously". I mean, I don't. But it may depend on what you want. My situation :
Tablet -> WiFi -> Router -> LAN Cable -> Music Server (means : contains the music data).
Now careful :
Music Server -> LAN Cable -> Audio PC.
The above is the physical connection. Now the functional one :
Tablet(RDC) <-> Music Server (RDC) <-> Audio PC.
So Tablet controls the Audio PC via the Music Server.
No Audio PC is connected to the Internet here. Only to the Music Server.
The Music Server *is* connected to the Internet, but only because that is convenient for me. So if I detach the (in my case) ADSL cable from it, no internet but still all the required connections for audio.
« Reply #20 on: January 27, 2015, 08:22:08 pm »
Brian, something else :
Did you actually apply this : XXHighEnd settings for the NOS1a ?
I'm asking, because without applying that (sequence) nothing works in MinOS for what you want with it.
« Reply #21 on: January 27, 2015, 09:33:25 pm »
Will give that sequence a try. Thanks!
Dantana
« Reply #22 on: January 28, 2015, 04:34:36 am »
Well I'd have to disagree with the idea that XX settings don't make much of a difference. On the first day I received my "a" upgrade, I applied Peters settings above. The sound was a bit strange and, accounting for break in, I immediately reapplied my settings below and the sound was much better, but still things in the DAC needed to have some burn in time. After 10 plus days of 24/7 burn in time, it's clear to me that SFS and Clock resolution settings still make significant differences in my system (this is without any clock upgrade in the PC) I think the most significant change comes with the clock resolution. Before my "a" upgrade I had to set the clock res to 15. Going lower just made the sound too harsh. Now I've found the best setting to be 1, just the opposite from before. If I now set it at 15 the sound becomes noticeably grey. If I go to .5 it becomes noticeably harsh. Though not as dramatic a change, I find that a SFS of .4 works best for me. If I go to 20 or 60 SFS the sound gets too rounded and when I go below .4 it gets too harsh. The changes with SFS are certainly much more subtle than they were before the "a" upgrade but they are definitely there.
I haven't sorted out all the settings but using my settings below I'm currently totally amazed at the level of SQ I'm getting.
  I just received my upgraded NOS 1a and running-in for about a week now.
  Must really thank Peter and Ciska for the excellent job and service.
  Initially, I tried Peter's suggested XX settings, with my Bios settings also as per what Peter had recommended. The music was really good, much improved than before the upgrade.
  But I reverted to my previous XX settings, albeit with minor adjustments, and have to agree that even after the upgrade, they do make a difference to SQ. Current settings are denoted in my signature.
  Maybe it is placebo effect. But to me, the improvements I noticed are:
1. Lower noise-floor. Musical notes are even better separated. And there's more air and plenty of spatial information.
2. I can hear more details. Bass details are better defined, less muddled.
3. Better dynamics. Music is now more charged and lifelike.
Best regards.
Daniel
XXHighEnd PC
i7 3930K Hyperthreading On (12 cores) @0.43GHz, 16GB, Windows 8 Pro 64bit on SSD (ext batt. powered), XXHE on 4GB RAMDisk (IMDisk), music on OS SSD & LAN, DVD Drive power removed, USB 2 & 3 bios disabled
1.186i (Apr 15, 2015*)
Engine#4 Adaptive Mode / Q1/-/3/4/5 = 6/-/1/1/1 / Q1Factor = 1, Dev.Buffer = 4096, ClockRes = 1.0ms*, Memory = Straight Contiguous, Include Garbage Collect, SFS = 0.32*,max 120 , not Invert, Phase Alignment Off, Playerprio = Low, ThreadPrio = Realtime, Scheme = Core3-5, Not Switch Processors during Playback, Playback Drive 4GB RAMDisk (IMDisk), UnAttended, All Services Off, Keep LAN - Not Persist, No WallPaper, No OSD, No Running Time, Minimize OS, XTweaks : Balanced Load = 43 / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On, Double-Octo Custom Filter with Arc Prediction Upsampling, Driver v1.0.3 (2ms)
XXHighEnd PC via USB3 (Silverstone EC04-E, isolated*) > Clairixa USB cable* > 24/768 Phasure NOS1a async USB DAC > XLR > Soulution 725 Preamp* (XX vol. -6.0db)> Soulution 711 power amp > Magico M Project
Stanray
« Reply #23 on: January 28, 2015, 09:35:38 pm »
Now careful :
 scratching
So this "music server" needs 2 LAN ports and therefore can't be my old lappie?
Am I correct?
Stanley
« Reply #24 on: January 29, 2015, 12:28:42 am »
Am I correct?
Stanley
if you have a free USB port you can use an adapter.
http://www.advancetec.co.uk/edimax-eu-4208-usb-2-0-to-fast-10-100-ethernet-adapter-perfect-for-ultrabooks-pc-mac.html
« Reply #25 on: January 29, 2015, 08:24:52 am »
Now the functional [connection] :
[Highlight mine]
I've always wanted to do this. Is the procedure as simple as getting a crossover ethernet cable and then doing this: http://www.wikihow.com/Connect-Two-Computers-Together-with-an-Ethernet-Cable ?
« Reply #26 on: January 29, 2015, 08:57:42 am »
[Highlight mine]
I doubt you will even need the crossover cable Mani, just a normal one should be fine with modern ethernet controllers.
« Reply #27 on: January 29, 2015, 03:04:22 pm »
Yep, The magic word is "gigabit" Ethernet. Most recent mobos have these controllers on board.
Note that both pcs must have this kind of hardware support (or maybe not as I think of it).
Regards, Coen
« Reply #28 on: January 29, 2015, 08:01:53 pm »
scratching
Am I correct?
Stanley, essentially Yes. But then of course you can use the LAN cable to connect to the Audio PC directly (better think like connecting the Audio PC to the Laptop = your Music Server for easier functional thinking) - and use WiFi for connecting to the router (with WiFi capabilities).
OK, getting dizzy of it myself. Better make such small schematics yourself, so I can see what the full picture is. So notice that your case seems to imply a laptop as "Control PC", that also containing/providing  the music, but which connects to the Audio PC via LAN cable. Can be of course, but why to have the next LAN cable then ? Internet ? so then counts what I said : do that through WiFi (from the laptop).
hvdh
« Reply #29 on: January 29, 2015, 09:47:13 pm »
So I could basically buy one of these:
http://tweakers.net/pricewatch/268169/icidu-gigabit-pci-card.html
and connect the audio pc to the control pc directly instead of the router.
It's just that I feel that this still doesn't really answer my initial question... The audio pc will still be used as administrator, without virus scanner, and without UAC. And it will still be connected to the same network, right? So I have the feeling that even if I do this, it won't be too difficult to get infected by anything without even noticing (initially) Or am I wrong here?
But I have no idea if this concern is valid. Does the firewall give me sufficient protection if I don't use the internet from the audio pc???
