April 06, 2025, 11:53:00 pm *
Author Topic: Touch screen LCD cases and XXHE  (Read 19471 times)
« on: December 09, 2007, 02:03:07 pm »
I finally decided which case to get for my HTPC and I decided to go with a model with lcd touchscreen to browse my music library easily without turning the tv on.
Now my question is, will XXHE work fine in such way?
Looks need some improvement, i hope some skin and a fullscreen mode. Album or artist selection would be my favourite.
Good examples are MediaPortal (my favourite), Vista MCE (for music only) and Jriver.
« Reply #1 on: December 15, 2007, 11:45:13 am »
I don't think any touch screen as "we" intend for the job here will suffice, unless you use a pen to touch. I mean, all will be too small for fingers anyway.
Also, but this may be very personal, I don't think it is the way to set it all up. No matter what, you will be "squeezing" the playback machine (for disk space or other matters) and need an external display anyway (for larger jobs to do). Again, it will be personal.
Below you see my current touch device, wifi connected to the playback PC which is wherever it needs to be (near to the stereo equipment) and which is as large as it needs to be.
All can (IMO) be done as easy as possible if only a pen is used for the touch operations, but I just prefer a mouse.
Also note that you just can't do without a keyboard for the (now very extended Library Search in the upcoming 0.9t version), which of course can be done by means of the very awkward on-screen keyboard. So, here I'd prefer a keyboard again (for the device you see below I have a very nice small keyboard, not connected here).
Then there's another culprit, as I found;
The device as how I use it, is RDC (RDP) connected to the playback machine. However, the touch screen facilities like "rightclick" (i.e. press until the circle is full after which the context menu pops up) aren't recognized by the main PC (or I don't know how to set that up). Do note that when this is not working, touch screen operation is just not possible ! So here too, I have a mouse ...
Concluded : XXHighEnd allows for all, but it is other, general things that make it all awkwardish.
PS: The size of XX you see below is 640x480.The size of this screen is 800x480.
jsa
« Reply #2 on: December 15, 2007, 12:36:08 pm »
what is the model of the device that you use?
desktop on mobile processor Pentium T5500, motherboard Asus N4L-VM in Antec NSK2400 case -> various options tested currently : EMU0404PCI/PSAudio Digital Link III (usb DAC)/Benchmark  DAC1USB/ direct spdif from motherboard -> DAC CEC DX71mkI
« Reply #3 on: December 15, 2007, 01:37:40 pm »
Can you put a pic of that and tell me wich model? Looking for a real small/flat one some time now. prankster
Thanx  thankyou
Ps: Nice screen and the pull of beer too  Grin
« Reply #4 on: December 15, 2007, 02:25:23 pm »
http://www.microsoft.com/windows/products/winfamily/umpc/default.mspx
Note the thing weighs 960 grams. A tad too heavy for being ultra portable. Happy
It's an Asus R2h : http://www.pdashop.nl/product/31764/asus-r2h.html
At the top right it says : actual status : never deliverable anymore. ehh ...
Anyway, it has Wifi, bluetooth and ... GPRS (and GSM).
The alternatives on the mentioned page shown, are similar products indeed for what we want to do with it, although they 'll run XP I think (by itself unrelated when you use RDC), have less memory and some other rather unrelated things.
Important : Since this is a tablet PC, I think it is common that these devices are not as "touchable" as with normal touch screens. You'd really need a pen, or long finger nails (which I honestly don't have). Touching is done by firm tapping, and not by soft pressing like a finger would do.
« Reply #5 on: December 25, 2007, 01:23:52 am »
I have a wireless keyboard, wireless mouse and a Harmony 895. But for choosing the music (90% of the time album or composer), I like to browse the library of the htpc.
I like the interface of MediaPortal and they made a nice plugin to use almost all touchscreens. I think that on this matter XXHE interface needs some improvement.
Unfortunately I had to delay the completion of my HTPC because Intel delayed the penryn quadcores Q9300 and Q9450 (i'm getting the latter) to february-march, so I cannot test any touch screen functionality yet.
« Reply #6 on: December 31, 2007, 01:17:44 pm »
Maybe this is not exactly true ...
What I was doing before, was looking at all by means of RDC (RDP), so looking at the screen of a remote PC (the one where the music is actually played). When such a device is directly under control of a "tablet sensitive OS" (like XP/Tablet, or just Vista) stuff like scrollbars, close boxes and some more, are relatively large. In fact large enough to be controlled by fingers.
What remains is that such a device should (IMO) be used only to control a remote screen, and *then* this does not work ... Sad
« Reply #7 on: January 16, 2008, 07:48:33 pm »
I know that one can set the LCD screen as secondary screen (or primary if that matters) and the tv as the other, with a graphic card with two dvi ports it shouldnt be a problem, i.e. there can (and will) be different resolutions.
Second step, I need to setup girder and the Harmony. I wanna control XXHE mainly with my remote. i dont think it is possible to make XXHE a plugin of MediaPortal, exp because it is a paying software, but maybe i can browse my collection with it and then launch it when i select an album to play. Does it accept command line inputs? It should *wink*
Third step, if the above does not work, I would need to use Girder or similar software to make XXHE work with the remote. Having it touch-screen compatible would still be the best IMO.
Do you think to have attained an excellent, SQ, on par or superior to vinyl? I guess you do Happy Then you could dedicate most your efforts to adding features.
Lastly, I hope to have a remote device like kaleidascape has for both music and movies playback. I do not know any pocket-pc that is nice and ergonomic enough for this task yet. I'm sure that you have more experiences and have tried various combinations but i'm very picky with ergonomics and user interfaces.
« Reply #8 on: January 17, 2008, 04:16:19 am »
I have two responses that seem not much related, but they are. The first may look kind of stupid and hard to judge for the real merits :
The Library functions of XXHighEnd and the Galeries in special, are created with one thing in mind : a huge amount of data to be managed. "Huge" means several thousands of albums Explorer already can't handle because of the time it takes. So whatever front-end you want to use, anticipate on these amounts. I do / XX does, and it does it explicitly. "Manage" means that you can deal with it for functional reasons, and only when you have thousands of albums loaded, you can start to see what I mean with that and it is from various angles (like what to pick, where to store, how to find, how to backup and a few more).
The necessary speed of it all is already a bottleneck for everything, although I did not examine other software, but I think I know.
The power of the Galeries is so enormous that I dare say only two or three of you out there know what can be done with it, and added to that even I myself don't know yet how to exploit it all best, the latter because of it being so generic for possibilities.
Note that to my own findings the Library functions are just in their beginnings, and a next very powerful main feauture (encouraging for much more) you see in below picture (from the due 0.9t-6).
What you will see in the future, and what you might have learned from the past, is that there really is nothing I don't listen to, and eventually whatever it is one asked for is implemented. Mind you, unless "we" explicitly talked about it, and when I, say, can prove it isn't worth much. So here is the stupid part :
When to my judgement XXHighEnd is far better in whatever area than anything else, or I know because of developments to come that it will, there is no reason to spend time on "interfacing" with other software. Mind you, there is no reason for *me*. Going along with it, is the logic of better spending the time on the functionality (etc.) this other software might be better at, than spending time on that interface, knowing that XX will be as good on the matter concerned, might it be sooner or later.
Again, this sounds stupid but it is my strategy anyway. Not enough time to do it otherwise !
Let me try to give an example of which I hope I won't offend anywone but the developer who seems to be vanished anyway :
People exist who like MP3Toys as a front end. So there's the question : could XX not be controlled by it (because Foobar can and blahblahblah). So yes, I could make that. But man, software like that is so much outside my own standards (for decency) by far that I would degrade myself (or (future) XX) by doing it. So I don't already for that reason. More important though is that those who want/use MP3Toys, apparently don't see the "problems" you'd have when using that instead of XX itself, all ending up in me solving those problems which really aren't of my interest apart from you being that customer of mine. Also, I *know* that interfaces are the most hard to create and maintain, and most often something not working anymore is beyond both parties knowlegde and blame (like : "hey, it doesn't work with Vista SP1 !").
I know, a command line interface doesn't seem much (work), but when it's there it should be there for the good reasons. In fact I can tell you it's already there, but the means to exploit it for *my* reasons are not, and that's why you don't have it. At the time it is freed to you, yes, you could use it to let front end software control XX, but let's say that's a coincidence and it won't be supported.
Coming to the second part of my response, and I think this is less stupid, my before mentioned "good reasons" would be remote control, and might you not know, this is a whole world of knowledge and experience in itself. Since you mention Girder it might be so that you have good experiences with that in the HTPC/Movie environment, where btw 50% of my roots are too. The very major difference is though, that with movies you have OSDs (On screen Display) and you can see what yo are doing. Audio playback however, inheretantly works with the smallest device possible, that coincidentally being very close to you otherwise you can't see anything, that by itself urging for touching the screen since it is under your nose anyway. too much !
Now what ?!
This is a subject I couldn't work out so far myself. I do try though, if you'd only know that the Asus mentioned earlier in this thread is one of the attempts to find out, a Philips Pronto is another (talking about costs swoon) and yesterday the postman brought a Harmony.
At this moment I think it comes down to a most simple form : infrared remote control with any random generic programmable remote (think of Harmony like devices), and XX accepting commands as smart as we can all think of. How that makes us selecting albums/tracks without a visual ... scratching ... but if you'd compare it with a normal CDP, well, then yes.
With this rather unnecessary long response, the least I could do is indicate that I don't know it myself, at all. Any ideas are welcome for that matter. I'm sure everyone has ideas, so please vent ! Might I not respond to one, please know that I do read and take into account all. In the end there will be something I guess ...
sleeping
« Reply #9 on: January 17, 2008, 09:54:55 pm »
Hello Peter,
Thanks for replying. I think most of the current XXHE users use their computer transports for music only, therefore just remote control without anything visual would be good enough. But I want more from my htpc Happy
I do not have thousands of albums. I think I have between 500 and 800. Anyway, media portal and WMP11 have already good search features, listing by genre etc. I havent done ax extensive comparison, though. I see XXHE similar to WMP, expecially considering the pc-looking interface. The problem for me is that it cannot be read from 2-3m in a 7" inches screen. Give me something like Classé Omega CDP and we start talking Happy
Even cics CMP (in the thread above this) is readable on a HTPC screen.
When XX will have skins that will have text that looks good, not like a windows program and be readable at 2.5m of distance, then I won't have need to use a different frontend. I do like things simple. I will surely prefer to use only XXHE to play music. Ideally it'll be launched from the main window of mediaportal (play music), not from windows taskbar. Touching the screen or, sit, with my harmony.
I dont know what is mp3toys and I have tried many media centers, vista one, meedio, and other 4-5. basically everything that is available for windows and linux (yep, i tried that too, in a virtual machine). So far, mediaportal is the best. It can launch external applications (altough one plugin is bugged in vista), and I use TheaterTek for playing dvds and divx, since it is the best player and has memory. I do find the SQ with asio and a better plugin than the original close to (without exclusive mode, until I replace my terratec on the test pc).
Girder is a paying software. Before I will need to use it I hope XXHE will support infrared commands. There is another utility which is free but is less powerful. The Harmony itself can mimic windows media center remote, which makes easy to use most interfaces. I'm really eager to see XXHE respond to my Harmony.
I do not understand why. TheaterTek for instance has a command line interface to launch it ant it works very well and users like it. If It hadnt maybe I wouldnt have bought it.
Now what ?!
A normal cdp has a vfd screen that shows some data. Some have cd-text feature. A HTPC frontend can and must show more information. For instance, another mediaportal plugin shows the lyrics of the song that you are playing (it retrieves lyrics for about 60-70% of my songs and store them on my computer): that is very nifty, expecially for those of us who are not english native speakers.
And I want to see everything from distance. I do not want to power on the TV to read it.
Maybe in one year from now all this will be taken from granted by the users of XXHE, maybe not, maybe just some. I wanna dream the perfect interface.
