April 05, 2025, 01:37:35 am *
Pages: 1 2 3 4 [5]  All
Author Topic: Os-x yosemite driver?  (Read 76756 times)
« Reply #60 on: January 15, 2015, 06:35:14 pm »
To those concerned :
I just sent an email with a new driver and which works. Ehm if I tested all decently this time. Wink
Small problem, this one too has version 2.0.8. But per instructions in the email you will be fine.
« Reply #61 on: January 19, 2015, 11:44:17 am »
I am actually waiting for some feedback ...
Not that you need to try when not intended in the first place, but I assume someone did ?
« Reply #62 on: January 19, 2015, 04:53:22 pm »
All worked fine on my laptop. That is no problems with switching between base 44k1 and 48k frequencies on Audirvana +. All played!
Still there are some ticks and interruptions at 8x rate. Maybe my laptop (i5 based) is too slow. Different buffer sizes do not matter.
Regards, Coe
« Reply #63 on: January 19, 2015, 04:58:58 pm »
Hey Coe(n),
How would you describe this (better) ? When, frequency of it and such. If you have some spare time of course.
Thanks !!
« Reply #64 on: January 20, 2015, 09:11:59 am »
The ticks are only noticable with classical music and not on very quiet passages. I guess in the order of every 4-10 seconds. Furthermore the trackpad gets priority over the music playing, when moving the cursor the music immediately OR after a few seconds breaks up with  static for a second and continues normally. It sounds like "krr krr krr..." and the music runs in its normal pace through this interruption.
 Also when the os locks into the start screen or occasionally runs a prioritised process the break up occurs. The priority setting in audirvana plus does not really make a difference. Closing all programs including the wifi connectivity seems to alliviate the problem a little, that is there is a less direct response to the moving of the cursor.
HQ player exhibits the same behaviour yet is worse. There is a total breakdown of the music for a couple of seconds before the music restores.
At best I can listen a short music track without interruptions with audirvana plus.
Regards, Coen
« Reply #65 on: January 20, 2015, 01:51:42 pm »
Thank you Coen.
Is this happening "as easily" at a lower output rate ? ( like 352.8 )
Just trying to find out whether it can be a "not enough juice" issue.
Also, how bearable is this "static" ? So notice that static as such is window breaking. "Krrr krrr" does not seem to be like that. I'm asking because I like to observe myself by listening (instead of looking through analysers) but since I don't have a pre-amp or other means of analogue attenuation ... I like to keep my windows in.
« Reply #66 on: January 21, 2015, 04:26:50 pm »
Audirvana plus ends at 352.8/384 so that's what I'm talking about. Same problems with 176,4/192 (4x), but 2x seems to work better (like 192 source material x2 = 384) with less interruptions.
HQ player break up becomes less severe at lower rates but remains at all sampling rates.
I will have to check 1x for you.
The break up is quite disturbing in all cases. Read krr krr krr as broken music (lots of static) with silence in between. The static part seems to have a rhythm to it that is unique for Audirvana plus. With HQ player the sound 'just' collapses in to noise and finally silence to recover via noise into normal music again.
regards, Coen
« Reply #67 on: January 21, 2015, 05:08:59 pm »
Thank you very much Coen. And really no need to try 1x.
PeterC
« Reply #68 on: January 22, 2015, 02:14:00 am »
I have now used Yosemite driver 2.08a with complete success.  I have played using HQPlayer at 768 and 705 (44.1 material upsampled by HQP) and both play at correct speed (by timer) with no sound issues at all.
Thanks for resolving this from my perspective.
Regards, Peter C
W10-14393 in boot camp on Mac Mini I7 Late 2012 with Smps replaced by UpTone JS2 lps and MMK linear fan controller (4 core; 8 cores hyperthread),16GB RAM, music on FireWire drive; no video connection, control via Ethernet to RDP on MacBookPro/ Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 4  (max 150) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/ UnAttended / Always Copy to XX Drive / Keep LAN - Persist / WallPaper On / OSD On / Running Time Off / Minimize OS / XTweaks : Balanced Load = *43* / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable / Custom Filter *High* 705600 -> Curious USB 0.8m -> UpTone ISORegen powered by Uptone LPS-1 ->Uptone solid link -> 24/768 Phasure NOS1a-> Audioquest Sky interlink -> Vandersteen M5-HP high pass filter ->Musical Fidelity A308CR Amp -> Vandersteen 3A Signature + dual 2Wq subs
« Reply #69 on: January 22, 2015, 08:16:20 am »
Hi there Peter,
All I personally want to say and especially to you : and it was about time !
This has been the siingle occasion that I recall that I (Phasure for that matter) was dependend on a third-party and apparently have been unable to speed up things. And if I would have been you I would have gone fairly mad and angry. I mean, 8 months ??
So thank you very much for your great patience, Peter. And for your help.
