April 05, 2025, 01:37:36 am *
Pages: 1 [2] 3 4 5  All
Author Topic: Os-x yosemite driver?  (Read 76757 times)
« Reply #15 on: October 23, 2014, 05:11:01 pm »
Previously, Jussi has always included 3 versions of HQPlayer in each download/install: Desktop, ASIO and NAA. The Desktop version is simply WASAPI. In both the ASIO and NAA versions, the '2-wire' checkbox in the settings area is grayed out. But I know Jussi has made some changes recently and there's only a single version of HQP now, with the option of selecting the output between WASAPI, ASIO and NAA. Perhaps the '2-wire' checkbox is no longer grayed out, giving the impression that it is active for ASIO and NAA? I don't know as I don't have the latest version of HQP. And of course, I'm only talking about the Windows version.
« Reply #16 on: October 23, 2014, 05:36:24 pm »
It seems that people can't get it to work with the Mac version of HQPlayer. And I can't test it.
I tried this on the Mac. After a lot of crashes I managed to get music in one channel. I tried a number of audio "software patch-panel" routings to no success. NOS1 768 switch made no difference.
Regards, Coen
« Reply #17 on: October 23, 2014, 05:38:55 pm »
No need to re-try Mani.
Well, I've just downloaded and installed the latest version of HQP and I can't get it to work at all. 1-wire, 2-wire, no upsampling, upsampling, etc, etc. It just doesn't seem to work with the NOS1a. I'm sure the last time I tried it was before the NOS1a upgrade. Is there something up with the Windows NOS1a driver (or the XX engine that we're using with the NOS1a)?
« Reply #18 on: October 23, 2014, 05:49:39 pm »
The only thing you can not do with another player for Windows (like HQP is one) is using 48 base material. OK, it will work but at the wrong speed. Otherwise ? nothing that I can think of.
One thing : I have noticed more regularly that WASAPI seems broken for the highest speed in XXHighEnd. But not even sure. So to be on the safe side I'd use 352.8 or 384) and that dual wire.
OK, this doesn't even make sense to myself.
« Reply #19 on: October 23, 2014, 05:51:26 pm »
Hey Coen, thanks !
Is that undistorted in itself ?
« Reply #20 on: October 24, 2014, 10:37:01 am »
Hey Coen, thanks !
That was with the old driver/old OS and music was undistorted.
regards, Coen
« Reply #21 on: October 24, 2014, 11:31:01 am »
Coen, I am sorry but I can not interpret your answer.
You told about the new driver outputting in the left channel only when 24/768 (705.6) is attempted with HQ;
I asked (or tried to) whether the sound is undistorted (so all OK but from one speaker only).
Thanks ...
Bob Stern
« Reply #22 on: November 21, 2014, 10:36:39 am »
Obtaining a "license" for the things which need to be done here takes 6-8 weeks, and that is easily rejected. So I hope Apple reads this: because of this uncertanty "we" use licenses from someone else because otherwise it is undoable. "We" = a whole world. This is not even illegal but the "publisher" is not Phasure now and this may look strange. But it is what I chose for.
It is not really about the programming on the driver (which sure is what I do myself) but about generating the "build". And it is this part which all the time fails because of an Apple change in 10.10 with (as it looks) no downward compatibility. In itself such a thing happens more often, but in this case the install itself fails in a destructive way which can't be turned around. Or maybe now, because the guys helping me also need guessing while they can't try it themselves because all had to start with an install like Coen's (or my own) which needs to fail first in order to mimic the behavior.
Peter, I believe you can speed up the beta testing if some users are willing to disable Yosemite's "kernel extension signing" by storing the "kext-dev-mode=1" parameter in nvram as described in the first Step 5 here:
http://www.cindori.org/trim-enabler-and-yosemite/
« Reply #23 on: November 21, 2014, 11:02:04 am »
Hi there Bob - thank you for this !
« Reply #24 on: December 30, 2014, 09:22:05 am »
FYI:
I have a new driver available (if all is right for OSX8 and up) but I could not test it myself. Also, the couple who were actually waiting for this are all doing other things at this moment (Christmas Holidays and such), so ...
So if someone thinks he can use it, drop me an email.
This Mac driver is useful for two reasons :
1. Those who need it (for NOS1) on OSX10;
2. Those who own the NOS1a and like to switch base clock rates (44.1 vs 48).
Ad 2
Please notice : Only after someone has tried it, we know it works.
« Reply #25 on: December 30, 2014, 09:41:47 pm »
How new is this one?
I can check it out on i5 MBP 2013.
Regards, Coen
« Reply #26 on: December 30, 2014, 11:30:58 pm »
Hi Coen,
Not sure what you mean, unless I say 1 week and you understand that ...
« Reply #27 on: December 31, 2014, 02:09:33 pm »
That's more recent than the one I have. Please pm me.
Regards,Coen
« Reply #28 on: January 01, 2015, 11:18:23 pm »
Ad 2
at first: Happy new year to everyone!
The fruit of my endeavor:
I used A+ 1.5.10 on the MBP and I take it the driver should do the base clock changing, because I cannot find another way to do it.
Only with source material at base 48kHz I get music, with the 44.1KHz base A+ produces only static at higher sampling rates (2x etc). Pure NOS ("1xOS") it plays a little but fast forwards every now and then. Very strange behavior.
Oh and the base 44.1 material sampled to base 48 sounds to slow,
So either I don't know how to configure the system or it doesn't work.
regards, Coen
p.s. the driver version in the panel is 2.08.00.
michaeljeger
Headphone Maniac
« Reply #29 on: January 03, 2015, 03:17:34 pm »
Hi
Same findings as Coen.
This driver is not working at all.
44.1k playing too fast, and after a couple of seconds heavy dropouts.
48k playing with right speed but also after a couple of seconds, sound becomes totally distorted, dropouts etc.
Unfortunatly, I do not have the former driver version (2.7.0) anymore so for the moment I cannot play at all.
Regards, Michael
Page created in 0.013 seconds with 16 queries.
