April 06, 2025, 02:45:59 pm *
Pages: [1] 2 3 4 5  All
Author Topic: Os-x yosemite driver?  (Read 76775 times)
« on: October 22, 2014, 09:10:18 am »
FYI:
I moved forward to Yosemite. Not entirely unexpected the NOS1 driver doesn't work anymore. I've re-installed the current driver in several ways but the NOS1 is not recognized.
Is the new driver Yosemite-proof?
Regards, Coen
« Reply #1 on: October 22, 2014, 09:29:23 am »
Hi Coen - Yes. That is, if it works in the first place of course.
I was handed another attempt yesterday late afternoon, so this afternoon I am going to try that.
And I say it again (or maybe I did not say it at all) what a supersh*t this Apple environment is. YOU-DO-NOT-WANT-TO-KNOW. Those guys are just totally crazy.
And Coen, you may just have ran into an example of that and which is all what I am experiencing similarly; you installed a wrong driver (you stupid !) on a wrong OS and you most probably will not be able to ever get it working again. So it is about THAT.
And hey, did you see anything FAIL ? No no no, you see very green large OK marks. And now you are already stuck because of these OK marks and you won't know what you're at.
Anyway, this is how it's going on for myself for weeks now. Meanwhile I need to know as much about OSX as about Windows in order to get things right again. So FYI : What currently is going on is that any wrongly installed driver won't let itself over-write anymore (read : you can't uninstall it and you also can't install a new one while all says it's OK).
The uninstall can be done manually though (delete a couple of files) but it should go automatically.
Apple keeps on changing things and it is a complete hell. They just do what they like and leave it to poor guys like application developers and in this case driver developers.
When all this work has been done, the consumer is not supposed to see anything of this.
Nothing of the slightest kind happens ever to Windows.
« Reply #2 on: October 22, 2014, 10:08:01 am »
Haha!
Now we're trading places: lost and frustrated developers instead of users!
Is there an OS where we can meet? Is the Linux environment even harder to manage or does it not have enough users?
Thanks anyway for the effort!
regards, Coen
michaeljeger
Headphone Maniac
« Reply #3 on: October 22, 2014, 11:00:18 am »
Hello Peter
Thanks for working on this.
Are you doing all the programming yourself?
Regards, Michael
« Reply #4 on: October 22, 2014, 11:59:41 am »
Michael - I wish I were. So this is part of the problem;
Obtaining a "license" for the things which need to be done here takes 6-8 weeks, and that is easily rejected. So I hope Apple reads this : because of this uncertanty "we" use licenses from someone else because otherwise it is undoable. "We" = a whole world. This is not even illegal but the "publisher" is not Phasure now and this may look strange. But it is what I chose for.
It is not really about the programming on the driver (which sure is what I do myself) but about generating the "build". And it is this part which all the time fails because of an Apple change in 10.10 with (as it looks) no downward compatibility. In itself such a thing happens more often, but in this case the install itself fails in a destructive way which can't be turned around. Or maybe now, because the guys helping me also need guessing while they can't try it themselves because all had to start with an install like Coen's (or my own) which needs to fail first in order to mimic the behavior.
More later today ...
michaeljeger
Headphone Maniac
« Reply #5 on: October 22, 2014, 01:49:04 pm »
Sorry to hear it is so difficult.
Thanks for the update.
Regards, Michael
« Reply #6 on: October 22, 2014, 04:47:38 pm »
Coen,
As it turns out (only now) the new driver does not work on 10.7. 10.8 should be OK but was not tested (anywhere). 10.9 and 10.10 has been tested but not by me because ... I'm on 10.7.
Can you please test this ASAP ?
I just sent you the driver (in 2.6.0 version as you will see it for the Mac).
Thanks a lot, also on behalf of others ...
« Reply #7 on: October 23, 2014, 12:27:11 am »
I allready PMd Peter,
I did not try the 2.6.0 but the 2.7.0.
Installation run very fast. After the reboot the NOS1 was recognized and music playing within the minute!
I've let it play while messing around and noticed that there are tics with certain tracks with A+ and interruptions with a "krrr" sound associated with cursormovement. This is on battery mode. In "slow" filtermode (less cpu intensive), extreme priority and/or all other applications closed the ticks seem to remain. Not saying this IS about the driver but it could be.
regards, Coen
PeterC
« Reply #8 on: October 23, 2014, 12:37:33 am »
As a long time lurker on this forum I am motivated to register and respond that the driver version 2.7.0 that Peter sent me is working without any ticks or unexpected behaviour on my system...
OS X Yosemite + HQPlayer on Mid-2010 Mac Mini up-sampling to 384 with cpu load around 25% to Phasure NOS1a.
Regards, Peter C
W10-14393 in boot camp on Mac Mini I7 Late 2012 with Smps replaced by UpTone JS2 lps and MMK linear fan controller (4 core; 8 cores hyperthread),16GB RAM, music on FireWire drive; no video connection, control via Ethernet to RDP on MacBookPro/ Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 4  (max 150) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/ UnAttended / Always Copy to XX Drive / Keep LAN - Persist / WallPaper On / OSD On / Running Time Off / Minimize OS / XTweaks : Balanced Load = *43* / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable / Custom Filter *High* 705600 -> Curious USB 0.8m -> UpTone ISORegen powered by Uptone LPS-1 ->Uptone solid link -> 24/768 Phasure NOS1a-> Audioquest Sky interlink -> Vandersteen M5-HP high pass filter ->Musical Fidelity A308CR Amp -> Vandersteen 3A Signature + dual 2Wq subs
michaeljeger
Headphone Maniac
« Reply #9 on: October 23, 2014, 08:16:48 am »
Hello Fellow Mac Users
In my understanding with the drivers, you should be able to upsammple to the max. possible sample rate of 768kHz.
Can anybody confirm that this is either working in Audirvana or HQ Player?
Regards, Michael
« Reply #10 on: October 23, 2014, 10:04:08 am »
Hey Coen,
Saw nothing. Not important, so just saying ...
But thank you for tryig ans super of course !
About the "krrr" sound ... try another USB port (on the Mini they are not the same electrically (and lousy to begin with). If that does not help check your grounding (swoonswoon Happy).
So "hearing your mouse" is always about grounding.
« Reply #11 on: October 23, 2014, 10:05:52 am »
Hi there Peter.
Thank you very much for lettings us know and trying.
And wasn't it about time ... yes
« Reply #12 on: October 23, 2014, 03:39:50 pm »
Mani,
I think you once told that you tried the NOS1 with HQPlayer on Windows and could use the Dual Wire option to output 705.6/768.
Did this really work ?
It seems that people can't get it to work with the Mac version of HQPlayer. And I can't test it.
« Reply #13 on: October 23, 2014, 04:15:55 pm »
Hey Peter, yep it definitely works. But you have to use WASAPI - ASIO only does single wire.
I haven't tried it for quite a while, but can do so easily if you'd like me to.
HTH.
« Reply #14 on: October 23, 2014, 04:53:34 pm »
Wow, that's quick ! Thank you !
Oh, then maybe it doesn't work on the Mac ?
If anyone knows more ... ?
No need to re-try Mani.
Thank you ...
Page created in 0.116 seconds with 19 queries.
