« Reply #60 on: October 30, 2014, 02:48:40 pm » |
Hi VJ, I'm definitely interested in giving it a go. I've sent you a PM...
Cheers, Mani.
« Reply #61 on: October 30, 2014, 09:26:49 pm » |
Hey VJ, I assume a US tour too? I have a 6' YFS v4 data only. Would love to see if there is a difference with about a 3' "reference" version of the YFS cable.  Let me know and thanks so much for putting this together! Brian
vrao
« Reply #62 on: October 31, 2014, 03:06:08 am » |
Ofcourse! As soon as the cable returns from Europe!
Mamba315
Ferrari NOS1a
« Reply #63 on: October 31, 2014, 05:57:12 am » |
I would be interested in US tour when the time comes. I'm in central CA.
vrao
« Reply #64 on: October 31, 2014, 06:25:14 am » |
I'll send out a notification for the U.S. tour!! All are welcome
fmanheck
« Reply #65 on: October 31, 2014, 10:47:45 am » |
I have had to forego the tour as I bought before it started  If anyone is in the Boston area, they are more than welcome to come listen
MACH lll PC 14/28 / RAM OS 10493/ 2.10 Phasure NOS1a G3 24/768 USB DAC KS mode -Adaptive/Device buffer -4096/DAC is 32bits 768khz/DAC needs -32bits/Phase Alignment - NO/Format Change - enable/ Decode HDCD ON/Processor Core Appointment 3-5/Player Prio LOW/Thread Prio Real Time/Clock Res 15ms/Xtweaks 64,1,1,0,1/ SFS 5.19 MAX 120/Include garbage collect ON/Copy to XXdrive by standard ON/Stop Desktop ON/Stop Remaining ON/Stop Wasapi ON/Keep LAN ON/Use remote desktop ON/Persist ON/OSD ON/Coverart show Wallpaper, show back, at attended, show mirror back/ Q1,3,4,5,xQ1-30,1,1,0,1/40/ Amp: Music Reference RM200 HC version / Speakers Omega HO Alnico Monitors with Audio Smile Super Tweeters Bass augmented by 2 GR Research OB subwoofers
« Reply #66 on: October 31, 2014, 05:29:18 pm » |
Hahaha, expect 10+ No wait, 11+ since about now. You know ...
fmanheck
« Reply #67 on: October 31, 2014, 10:55:07 pm » |
HAHAHAHA Yes I do know. But I did not know 10+ near Boston  Sounds like time for PARTY  I can line up a caterer AND the cable  Not to mention the NOS1a  Life is good
« Reply #68 on: December 05, 2014, 12:34:31 pm » |
FYI: YFS is passed on to Stanley (Stanray). He has quite a different setup so I am looking forward to his first impressions.
Hopefully this weekend I will find the time to post some closing remarks. These will include my impressions of a 0,7m Supra USB2 cable. But first: Sinterklaas!
regards, Coen
« Reply #69 on: December 05, 2014, 05:36:35 pm » |
But first: Sinterklaas! I can't help it, but this one I play once per year on this evening. For years and years and years by now. (and getting better each year  )
« Reply #70 on: December 05, 2014, 09:34:59 pm » |
LOL!!! That must be fun! For the curious: http://youtu.be/tpf6dhZXYGYRegards, Coen
« Reply #71 on: December 05, 2014, 10:30:25 pm » |
OMG! I can't believe I just listened to that.
« Reply #72 on: December 06, 2014, 12:35:29 am » |
I endorse Anthony's words... This hasn't been recorded on our planet ?   Alain
Michel
« Reply #73 on: December 06, 2014, 12:15:49 pm » |
stampen  Good old days... Damn iam getting old! Regards Michel
« Reply #74 on: December 08, 2014, 11:46:42 pm » |
I promised some closing remarks on my time with the YFS cable. Here they are. I gave the cable some serious XX playlist time to give it a little extra 'burn in'. When I was ready to expose myself to the cooked cable my amplifier's right channel stopped working. This was eventually solved by a simple repair... only after 8 days. Just couldn't find the time to do this with a 'fresh' mood. So now I was completely reset auditorily and had a slightly improved amp to boot. What can I say, it's character of solid and very clear and detailed images remained as did the feel of dynamics, yet it all was dressed in a smoother jacket. But also even though listening to Kate & Peter and other tracks made more sense now, I think it ultimately didn't add up to the enhanced musical experience at my listening seat I hoped for. Lastly just before its departure, the Blaxius arrived. A quick listen did not reveal new things from the YFS, only that the Blaxius digs much deeper into the music which enhances the YFSs strong points. Now I would like to address my sincerest thanks for VJ and of course the cable proprietor who made this educational experience possible.  The cable is now further on its tour and I am looking forward to the impressions of the next in line. And I trust you to keep in mind that my comments are made in the context of my system and listening preferences and to be as unbiased as possible! regards, Coen
