« Reply #45 on: October 28, 2014, 08:32:35 pm » |
Today I´ve discovered this "double head" USB cable, has anyone heard about it?: http://www.audiocadabra.com/blog/optimus-handcrafted-dual-headed-usb-cables/Regards, Juan
Robert
« Reply #46 on: October 28, 2014, 08:50:56 pm » |
Has anyone tried the Lightspeed http://www.lightharmonic.com/lightspeed.html by all accounts the best at the moment? Gosh after spending lots of euros on the NOS1, computer front ends and Orelino's, I can't understand why some are trying to make a silk purse out of a pigs ear with cables. Same goes for interconnects with BNC. BNC is a very valid connection but the cable quality of most 75ohm commercial grade cables is not good enough for Hi-Fi. Cables should be considered a critical component same as a DAC. It is hard to justify some cable prices but listening is the proof. I can't go past Nordost these days and I've listened to lots plus made them. They do have crazy pricing but after listening can't live without them. Robert
Stanray
« Reply #47 on: October 28, 2014, 10:30:40 pm » |
« Reply #48 on: October 29, 2014, 12:54:25 am » |
Hi Robert, the amazing sound of the NOS1 with a BNC cable connection to the poweramp is dependent on the NOS1 (Christmas is coming soon), because with other DACs (Weiss) I did not get the same results by far. Prior to the 50 Ohm BNC cable I used RCA cables from Nordost (Valhalla) and later on one from Entreq. For a second hand Valhalla 1m RCA we have to pay at least € 1400,00 in Europe, and we get a first quality 1,5m BNC cable (RG223) for less than € 100,00. Joachim
vrao
« Reply #49 on: October 29, 2014, 02:05:38 am » |
Guys, Before looking at any other USB cable, please consider the YFS cable previously suggested. I have it playing for a week (however <100 hrs required for breakin), "clear" improvement in SNR by at least 6 dB from the stock cable. Btw Peters cable will be the default gold standard cable, considering it was the cable used for the development of NOS and XXHE! Maybe I'll ask Kevin if I can send this on a tour!  *edit* Kevin from YFS has agreed for a cable tour!! Requirement Phasure NOS -1/a DAC So people interested kindly PM me their info, and we can plan this tour. Hopefully we can find a way for our international phasure owners to try as well. Input on the forum will be appreciated! VJ P.s I don't specialize in this stuff, it's just my enthusiasm. (And my first time) So things might be sluggish and jittery!
michaeljeger
Headphone Maniac
« Reply #50 on: October 29, 2014, 08:28:02 am » |
Hi Robert, the amazing sound of the NOS1 with a BNC cable connection to the poweramp is dependent on the NOS1 (Christmas is coming soon), because with other DACs (Weiss) I did not get the same results by far. Prior to the 50 Ohm BNC cable I used RCA cables from Nordost (Valhalla) and later on one from Entreq. For a second hand Valhalla 1m RCA we have to pay at least € 1400,00 in Europe, and we get a first quality 1,5m BNC cable (RG223) for less than € 100,00. Joachim Hello Joachim Not sure but why are you not using XLR Cables? Is there any thread here explaining why BNC would be superior to even XLR? Speaking of XLR and Cables.... maybe people do not used them with their Phasure setup here not often. Regards, Michael
Custom Built XXHighend PC with Xeon processors and not fans -> XXHighend Player 2.02 with Win 10 10074 -> Claxius USB Cable -> Phasure NOS1a -> Blaxius Cable -> Violectric V281 Headphone Amp -> Abyss AB-1266 (best headphone in the world)
« Reply #51 on: October 29, 2014, 11:18:50 am » |
For further reading on USB cables in this forum, and the YFS data only cable in particular, look here, page 4. Not everyone who tried to replicate a data only cable had good results: http://www.phasure.com/index.php?topic=2701.45
« Reply #52 on: October 29, 2014, 12:54:57 pm » |
Hi Robert, the amazing sound of the NOS1 with a BNC cable connection to the poweramp is dependent on the NOS1 (Christmas is coming soon), because with other DACs (Weiss) I did not get the same results by far. Prior to the 50 Ohm BNC cable I used RCA cables from Nordost (Valhalla) and later on one from Entreq. For a second hand Valhalla 1m RCA we have to pay at least € 1400,00 in Europe, and we get a first quality 1,5m BNC cable (RG223) for less than € 100,00. Joachim Hello Joachim Not sure but why are you not using XLR Cables? Is there any thread here explaining why BNC would be superior to even XLR? Speaking of XLR and Cables.... maybe people do not used them with their Phasure setup here not often. Regards, Michael Hi Michael, I´m using XLR cables with my NOS1a and I´d like to try the BNC cables but it looks that the XLR/BNC adapters do not maintain the BNC impedance which seems to be essential to get the sound the BNC cable. Maybe someone has a solution for the ones that use XLR connections in order to use a BNC cable, or is it impossible? Kind regards, Juan
« Reply #53 on: October 29, 2014, 05:03:29 pm » |
Is there any thread here explaining why BNC would be superior to even XLR? Michael, quite hard to miss : Cables with BNC Connectors/Adapters Are Generating A Superoir SQ(Joachim already responded to this question from you, but he abusively put it in the topic itself (the one I just linked to)). Edit : Joachim's response to you is here : Re: Cables with BNC Connectors/Adapters Are Generating A Superoir SQPeter
« Reply #54 on: October 29, 2014, 05:18:20 pm » |
Yeah, well, maybe not. The QED site tells nothing about it and although the general description looks good to me (again), this does not at all : •Impedance 90Ω ± 15 Ω Notic that this is from the site you linked to, Stanley. Now laugh : Who ever made this nice line up made a small mistake (and notice this is thus not listed at the QED site). USB specifications are 90 Ohm +/ 15 %. Now do the math; 15% x 90 = ... 13.5. So deviation (+/-) is allowed to be 13.5 Ohm. And this one is the most officially listed as deviating 15 Ohm. Happy now ?      Obviously someone with the knowlegde made a typo. That is, I assume that this is not to let you fall in a pitfall. But still, who made up that figure in the first place ? Still thanks of course and maybe it is ok. But I'll refrain this time (just because I don't feel the need and not because I feel this won't work (again)). Best regards, Peter PS: Start to smell nastyness when anyone lists his cable as +/- 15% because this is just the USB2 spec. Also notice that the deviation like this *is* the spec because the impedance varies per frequency (say USB speed used). To me this doesn't tell at all that someone can come up with a +/- 10% for example. So the first one listing that will be my man (because there's no reason for it (because the spec is "less") so if it was done it must be "genuine" - at least that would be my view).
michaeljeger
Headphone Maniac
« Reply #55 on: October 29, 2014, 08:38:51 pm » |
Hello Peter Thanks for the link. This topic was not on my radar so far. Will read some more into it because most of it I do not really understand. One feedback I can give about the Supra USB cable: I do not like it. Will not use it further. I have another USB cable I prefer. I will see how they compare on the NOS1a. Regards, Michael
fmanheck
« Reply #56 on: October 29, 2014, 11:30:26 pm » |
I just installed the YFS Reference USB cable to the NOS1a. Not broken in yet but already highly recommended. I was actually surprised to hear such an audible difference. I guess I am replacing my $5 cable after all.
Something off topic but readily observed with the NOS1a; With the NOS1, I never really noticed a large difference with Hi-Res files vs. Redbook but now there is significant audible difference.
Usually for the better. Try Nora Jones "Come Away With Me" or U2 "Mysterious Ways"
Or not for the better. Try Cassandra Wilson "New Moon Daughter"
MACH lll PC 14/28 / RAM OS 10493/ 2.10 Phasure NOS1a G3 24/768 USB DAC KS mode -Adaptive/Device buffer -4096/DAC is 32bits 768khz/DAC needs -32bits/Phase Alignment - NO/Format Change - enable/ Decode HDCD ON/Processor Core Appointment 3-5/Player Prio LOW/Thread Prio Real Time/Clock Res 15ms/Xtweaks 64,1,1,0,1/ SFS 5.19 MAX 120/Include garbage collect ON/Copy to XXdrive by standard ON/Stop Desktop ON/Stop Remaining ON/Stop Wasapi ON/Keep LAN ON/Use remote desktop ON/Persist ON/OSD ON/Coverart show Wallpaper, show back, at attended, show mirror back/ Q1,3,4,5,xQ1-30,1,1,0,1/40/ Amp: Music Reference RM200 HC version / Speakers Omega HO Alnico Monitors with Audio Smile Super Tweeters Bass augmented by 2 GR Research OB subwoofers
« Reply #57 on: October 30, 2014, 09:16:22 am » |
WOW, I just spent 20 minutes reading in there. Funny how all reads as "never seen before" just because one year later quite some contexts changed (for me at least). Highly recommended to read (I started at that page 4) because I think it may set our minds straight in the context of "USB Cables do matter" - which really wasn't my own adoption that year ago ... (for NOS1 that was). Peter
« Reply #58 on: October 30, 2014, 09:21:17 am » |
Something off topic but readily observed with the NOS1a; With the NOS1, I never really noticed a large difference with Hi-Res files vs. Redbook but now there is significant audible difference. I can tell you ... I have been waiting for a post about this. So off topic or not, this has been my own notice about Hires right since the NOS1a. Maybe a little different from your observation, because it seems that I now can play Hires without most of the time disliking it. So I'd say Hires got better from it ? But not for this topic. So if anyone has some more explicits to say about this, please feel free to open a topic for it. Peter
vrao
« Reply #59 on: October 30, 2014, 02:09:00 pm » |
The YFS cable tour will start in Europe.  A 1.0 m length cable will be shipped out soon. everyone will have 1 week to try it out. so anyone interested let me know!
