April 06, 2025, 10:15:29 pm *
Pages: 1 [2] 3 4 5 6  All
Author Topic: Req: any USB cable tips?  (Read 83560 times)
michaeljeger
Headphone Maniac
« Reply #15 on: October 20, 2014, 05:16:00 pm »
I also just ordered the Supra USB Cable mentioned above.
Should be here within a week.
https://www.hifisound.de/Hifi-Zubehoer/Kabel-konfektioniert/Digital/SUPRA-USB-2-0-A-B-KABEL.html
Regards, Michael
« Reply #16 on: October 20, 2014, 06:41:23 pm »
A bit stupid that the Supra is nowhere on stock else than in Sweden (as it seems). I never like to wait forever ...
So this is the only reason I did not try it myself - really.
« Reply #17 on: October 20, 2014, 06:56:54 pm »
You can find it in Amazon UK or Amazon Spain
« Reply #18 on: October 21, 2014, 10:22:12 am »
Is there any issues with the DAC and server sync ? Any downsides otherwise for a data only cable?
Thanks in advance
VJ
Hi VJ,
when you have a look to the following link
http://www.phasure.com/index.php?topic=1744.msg17482#msg17482
under Specifications,
where Peter mentioned:(NOS1) - USB is powered by an internal dedicated linear power supply.
So, the USB cable from the PC to the NOS1 carries "datas" only.
Until now I did not face any problems with the "data only" USB cable (everything is in "sync").
vrao
« Reply #19 on: October 24, 2014, 03:28:36 am »
Just got the YFS cable in and running this PM.
 very happy
« Reply #20 on: October 25, 2014, 02:04:18 pm »
Anyone received his Supra cable yet ? Results ?
I know of one, bit his NOS1a id not arrive yet. swoon
Mine just arrived. Will try it tonight.
PS: Thank you Juan - I never considered Amazon. But it was not available in Spain; in Germany it was (2 left at the moment I ordered).
Edit : Of the 2m I needed.
Stanray
« Reply #21 on: October 25, 2014, 03:44:48 pm »
Still waiting for the 0,7m  unhappy
Stanley
Michel
« Reply #22 on: October 25, 2014, 11:53:09 pm »
Maybe an option to make the usb cable? You can specify what you want.
For I about  35 a 45, - for one meter. At least that's what I paid. This 1 have is better than the Kimber cable usb i had.
I can not mention the name, I assume? The guy lives in The Netherlands.(Almelo)  Grin?
Greetings
Michel
« Reply #23 on: October 26, 2014, 10:32:12 am »
Hi Michael,
You can mention what you want. But it's a sort of your responsibility that dozens of people are going to try it because you say it will be for the better. Also see next post ...
« Reply #24 on: October 26, 2014, 10:52:48 am »
All,
Let me start like this :
The back of the package the Supra cable comes in, even more states what we like :
"PE insulated wires with correct 90 Ohms impedance design".
And from seeing the package my readily remark was : HOAX.
How ?
It does not matter when you put out nice texts like I just quoted if you next literally destroy the dielectricum of the cable with such tight tierips that it almost makes the internal wires bare.
I forgot the number of windings needed for this 2m cable in the package, but say 5 and with two tierips so super tight the cable is molested at 10 places.
True, without knowing the dilectricum it feels and weighs like the air needed to create something like "correct 90 Ohm" but if this is the treatment afterwards ... no
But of course I was hopeful and at 7:30pm the cable went in;
I had been playing for 1.5 hour so so in advance of that and at a third track of the album playing I pressed Pause, changed cables and pressed Play again. Now envision (and believe me) :
Within 2 seconds I said WHAT !?
boom-boom-boom-boom - that is what I heard. And yes, those 2 seconds are for real so that bad.
It was after not more than 20 seconds that I expressed a : nothing works. NOTHING. So much nothing that I can't begin to point it out (and I won't). There was totally no music coming from anywhere.
This happened in a stage of co-listeners doing other things so whatever I said was not really heard or talked about. All I noticed is that someone put on headphones connected to an iPad and that lasted for the whole session (which was to 10:30pm). This was very rare to begin with.
Meanwhile I was seeking and seeking for music which wanted to "play" but could not find anything. All I knew was "hold on Peter, maybe some breaking in is required". Yeah, well ...
At this 10:30pm when the music was stopped, the headphone person finally took them off and THEN said : well, that was such sh*t - better don't do that again.
Ehm, I thought you were not listening ?
Answer : why do you think I put on those headphones in the first place ? and besides, no headphones helped anyway.
Oh.
Well, the least I could do was being gracefully thankful for the proof it wasn't my ears or mood.
I could try to think that it's the tierips. Officially that will be so, but suddenly *that* bad ? I can't tell and I can't repair it either. One hint : when you receive this cable, you most probably will see the same and you should send it back and ask for a refund. Could be hard to explain to the seller (unless it is the manufacturer himself), but anyway you'll have these rights. Whether it is worth the effort is something else (but still 49 euros ex VAT).
Michael, I suppose your cable looks the same regarding the tierips ?
Bweh,
« Reply #25 on: October 26, 2014, 12:24:39 pm »
Oh no...
One of the reasons that I initially purchased a NOS1 was so that I could get off the USB cable merry-go-round.
Maybe I need to borrow my old Revelation Audio Labs USB cable from the guy I sold it to.
 Sad
« Reply #26 on: October 26, 2014, 12:42:02 pm »
The one I took out was the $1 stock one. That must be our luck ?
vrao
« Reply #27 on: October 26, 2014, 04:07:34 pm »
Supra Uses tin in a litz fashion.
I have prevoiusly used their speaker cables in the past.
« Reply #28 on: October 26, 2014, 08:09:46 pm »
Hmm, this isn't very promising.
No news on my 1m order, should have been 3-5 days, but possibly they meant 3-5 weeks.
I am going to order a couple of loose USB A and B connectors and solder them on the stock cable. Hopefully this will make better contact.
Regards, Coen
michaeljeger
Headphone Maniac
« Reply #29 on: October 26, 2014, 08:20:10 pm »
I also received the USB cable from Supra but I cannot really comment about it. As you know, my Phasure is about to be shipped and will arrive hopefully soon.
Can you tell me what exactly you mean by tierips?
Can you show on a photo what you mean exactly? Not really sure I understand.
Regards, Michael
