« on: October 13, 2014, 10:42:54 am » |
My standard USB cable is kind of broken. No matter how I connect it, after 10 minutes or so all error counters go bazerk. Sound collapses into static. Probably some buffer overflow.
No such thing with my cheapo 5 meter USB but unfortunately this cable has no Mojo. Differences between cables and such have become MAJOR since the NOS1a. Tried a more expensive one (35 euros) but the sound became awful.
Any recommendations for a 1.5-2m USB cable that suits the NOS1a?
Regards, Coen
« Reply #1 on: October 13, 2014, 11:48:05 am » |
Ah, good luck Coen. I began my own quest to find the 'USB cable holy grail' immediately after receiving my (first) upgraded NOS1a and noticing that USB cables now made a massive difference. But in the end, I was defeated - just way too difficult with so many other variables (such as new speakers, etc). In the end, I opted to stick with my 'expensive' USB cable, which I stupidly paid a lot of money for (more than the NOS1a upgrade!).
If I were in your position, I'd probably try the iFi Mercury cable. I won't cost the earth, and seems (purely from pics and reports online) as if it's well put together.
« Reply #2 on: October 13, 2014, 12:32:26 pm » |
« Reply #3 on: October 13, 2014, 01:15:33 pm » |
Hi Joachim,
Are your sure that a USB cable without power will work between the PC and the NOS1(a) ?
2 years ago I had an Sotm USB 3 PCIe card that has a switch to allow sending the 5V power in the USB cable or not.
To establish the connection it was necessary first to allow the power to flow between the PC and the NOS1, then (and only then) as soon as the 2 components connected, I could switch OFF the USB power...
I would test with an ordinary USB cable (on which the power is "masked" with a thin layer of isolation tape or plastic) first just to be on the safe side...
It seems that some dacs do not require this, but the NOS1 seem to use it at least for the connection time... (Peter ?)
Stanray
« Reply #4 on: October 13, 2014, 01:39:09 pm » |
Hi Coen, I was planning to buy this one: https://www.kabeltje.com/supra-usb-a-b-kabel-2-meter. Real (?) 90 ohm, because that might be the most important. Stanley
« Reply #5 on: October 13, 2014, 02:50:48 pm » |
Hi Joachim,
Hi Alain, somewhere Peter wrote no USB power connection between the PC and NOS1 is needed. I will look for his remark. I bought this cable (I think Juan recommended it) at NOS1 times and there was a benefit to hear. There aren't any problems with this cable for the NOS1 and NOS1a in my system. Joachim
« Reply #6 on: October 13, 2014, 02:58:35 pm » |
Maybe what I experienced has to do with the Sotm USB card itself ? I can't really say, since then I have removed it and now use the Silverstone PCIe card...
« Reply #7 on: October 13, 2014, 06:37:15 pm » |
The SOtM won't work without power. Don't ask me why. Otherwise the power is not needed for the NOS1(a).
« Reply #8 on: October 13, 2014, 06:41:53 pm » |
At last it "has it" in the specs : http://www.jenving.com/products/view/usb-2.0-a-b-blue-1m-1001907573... and this is rare to begin with. But since this cable is often reviewed well ... looks good ? The ones I found myself with explicit 90 Ohm spec (and then still wth +/-15% because that *is* the USB spec) can be counted on one finger and then still have to be made yourself (with the connectors). So good ? And for 45 euros ... a no-brainer I suppose. Stanley, nice find ! Peter
« Reply #9 on: October 13, 2014, 08:05:07 pm » |
Hi Peter, The sotm card needs power of course... I was talking about the switch that "cuts" the 5V that otherwise would be sent through the USB cable... Here is how they tell it... SOtm tX-USBexp Features USB port USB 3.0 compliant xHCI host controller PCI express x1 Gen2 interface Support for super-speed, high-speed, full-speed, and low-speed USB port power on/off functionOver current protection ESD protection Alain Edit: thinking about it again... I may not have understood your point - you mean that the Sotm will not work if power is not applied first at the USB port ?
« Reply #10 on: October 14, 2014, 09:11:23 am » |
Edit: thinking about it again... I may not have understood your point - you mean that the Sotm will not work if power is not applied first at the USB port ? Alain, exactly. I too wasn't the most clear, but logically there was nothing in my mind about the power to the card itself. So there's a dipswitch on it for USB power, and without that set to On the NOS1 will not work. Again, no clue why but the card will be not compliant somewhere. And not to forget, the card's latency is also not on par, so something is fishy in there. Do notice though that this experience is from when it was first out (over 3 years ago by now ?). Regards, Peter
« Reply #11 on: October 14, 2014, 05:49:52 pm » |
@all,
Thank for the tips! The tech specs of the supra cable looked sound to me so I ordered a 1m length that will arrive in the coming weeks.
I'm rather discouraged by the audibility of the USB cable since it will be another variable in the audio chain making it more difficult to optimize with the aid of others (that have different setups). Hopefully the nice specs will translate into superior sound.
I will also put some more effort in eliminating noise at the computer side. This may provide insight into to the vast differences in sound between usb cables (despite the undoubtedly excellent noise suppression in the NOS1a). Groundloops aside, I can envision reducing amplitude modulation of the carrier signal bij stabilizing the DC power and frequency modulation by enhancing the clock, which in itself is also for a large part a power supply stability solution. I hope that I catch noise on the USB powerline by these better supplies or maybe even disconnecting it at the USB3 card side. The design of the SUPRA cable may help here also.
regards, Coen
« Reply #12 on: October 20, 2014, 12:23:54 pm » |
If you want an exceptionally black back round, without high frequency grunge at very loud levels, you really ought to consider the data only cable Joachim posted about. You may initially feel that the sound is a bit soft compared to your out of the box USB printer cable but don't let that fool you. Turn it up, you'll be amazed.
« Reply #13 on: October 20, 2014, 03:14:23 pm » |
I´m using a Mapleshade USB 2.0 cable with the NOS1a as I did with the NOS1 and the results are great. Listening The Moody Blues "Nights in white satin" I can perceive much more ambient with this cable than with others, music and voice seems to be in a big space with perspective and a lot of air around rather than being a flat sound in a constrained place. This is an old recording but the ambient can be perceived, or not, easily with one cable or another. Another option I would not discard is Peter´s standard cable, I mean the one that comes with the NOS1. This is a very cheap and common cable but for some reason I find it a very good one, very close to the Mapleshade cable although perhaps a bit smoother (which could be better in some cases). Mapleshade Clearlink Plus: http://shop.mapleshadestore.com/prodinfo.asp?number=CLEARLINK3-B-PLRegards, Juan
