November 23, 2024, 01:47:16 am *
Author Topic: Error Phase = 09  (Read 9448 times)
luis
« on: September 14, 2014, 01:15:30 pm »
I get an error in Windows 7 (x86) when I execute xxHE:
"Proper inicialization FAILED, so further errors Will Occur;
Report this to Phasure please: Phase = 09 "
Thanks in advance
« Reply #1 on: September 14, 2014, 01:27:40 pm »
Hi there Luis,
It is a bit hard to tell for me what actually can go wrong here, but it has to be related to the AutoHotkey.exe process (which tries to start in this "phase"). Not that I ever saw this error ...
Are you sure you have downloaded the full 1.186a version ? So, are dozens of files in the folder you put it in ?
Regards (and welcome !),
luis
« Reply #2 on: September 15, 2014, 07:48:43 am »
Thanks for your help.
I have re-downloaded version 1.186a and all remains the same.
When launched, icon of xxHE can saw in task bar and a miniature of xxHE window emerging when mouse is over xxHE task-bar icon.
I am unable to maximize xxHE window, it stay minimized all the time.
« Reply #3 on: September 15, 2014, 08:04:09 am »
Luis,
Does AutoHotkey sound familiar to you ? I mean, do you use it for something else ?
luis
« Reply #4 on: September 15, 2014, 08:06:42 am »
I never used AutoHotKey  blink
« Reply #5 on: September 15, 2014, 08:14:37 am »
If you go to your xx folder (the folder in which you unzipped the download) and you doubleclick AutoHotkey.exe (green icon with an "H" in it), what happens ?
