April 01, 2025, 01:07:03 am *
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30]  All
Author Topic: Cables with BNC Connectors/Adapters Are Generating A Superoir SQ  (Read 591179 times)
« Reply #435 on: January 24, 2015, 06:32:45 pm »
Hi Peter, I realized that with the Blaxius the phase is changed, I mean sounds that were in the left speaker now are in the right speaker. I took a picture of the BNC cables in the board, it can be seen that the left cable goes to the left BNC connector and the right cable to the right connector. However there was not the red cable that you mentioned in your installation manual. Did I do something wrong?
« Reply #436 on: January 24, 2015, 07:26:33 pm »
Haha Juan, at least you noticed. Great test ! Wink
But Yes. The left output has to go to the right terminal and the right to the left.
No big deal to change of course (just exchange the output terminals).
And thank you very much for your feedback !
« Reply #437 on: January 24, 2015, 10:06:46 pm »
Ok, no problem. Thanks
« Reply #438 on: January 29, 2015, 03:16:40 pm »
So when I sent my NOS1 in for the "a" upgrade, I did not have my output resistors changed from 50 to 75 ohm. I had been so impressed with my RG 142, silver coated, solid copper bnc interconnect that I really wanted to hear the "a" upgrade without changing anything else. I suppose I was a bit worried that changing the DAC output resistance to 75 ohms would detract from the sound of my rg 142, 50 ohm cable. After letting the DAC and Blaxius interconnect burn I'm glad to report that hands down the Blaxius is the best cable I ever heard! All that was great about my RG 142 cable is made so much better with the Blaxius. I really did not think this was possible. Whats amazing too is that I'm currently using the Blaxius with 50 ohm output resistors and bnc/rca adapters and it sounds as described in all the posts above. For me though, the most impressive things about the Blaxius are the size of the soundstage and the resolution of the HF. Just amazing. Without distortion, I'm able to play at an average of 90-92db with peaks in the 96-98 db range, which for me is way too loud but not for everything!
Monday I'm having the 75 ohm output resistors and 75 ohm bnc connectors installed in the NOS1a as well as 75 ohm bnc connectors in my amp. Am salivating at the possibility of even better sound.
Thanks Peter
« Reply #439 on: February 01, 2015, 11:10:46 am »
Thank you for sharing Brian. I missed this post and only just saw it.
Enjoy !
michaeljeger
Headphone Maniac
« Reply #440 on: February 10, 2015, 09:47:03 am »
The Blaxius arrived yesterday.
It replaced a XLR interconnect from the NOS1a to the headphone amp I am using.
The interconnect I was using before was already very detailed but a tad too bright for my taste.
With the Blaxius I hear the following improvements over my interconnect:
- wider soundstage (not much but noticable)
- smoother treble without loosing detail
- slightly more bass impact
A very nice cable indeed. I imagine the difference will be even bigger for speaker cables, because of the length.
Very nice indeed, Peter!!!
Best, Michael
« Reply #441 on: February 10, 2015, 09:56:55 am »
Ha, nice Michael !
rutger21
« Reply #442 on: October 11, 2017, 09:09:47 pm »
I have been lucky enough over the years to have owned what i believe to be some of the best IC`s on the market such as top tier Teo, High fidelity, Elrod, Sunyata, Silversmith palladium etc. Without attempting to explain with any of the usual audiophile terminology..... Blaxius is simply a step above whilst saving $$$$
Huge credit to you Peter. Especially considering cables are not exactly your thang. Very impressive!
I am honestly saying this without even hearing Blaxius on my NOS1a yet(due to circumstances) or in B-75 mode obviously. Merely connected to my makeshift Oppo-105 and integrated amp. I think i am definitely in for a treat when i connect my main system back up.
Some of you guys here, i assume, may not really know how good this Blaxius cable really is. I think many of you are actually quite spoilt with this cable. Coming from a crazy cable veteran in our crazy world of `hi-end` cables i really believe Blaxius is the REAL deal.
IMO all you guys owning Blaxius are missing out on nothing.
Can`t wait to hear this on my NOS1/Orelo. So far truly impressive!
Thank you ! to you Peter
Pete
« Reply #443 on: October 12, 2017, 01:01:26 pm »
Thank you Pete. Hips - oops
Oops, sorry, wrong smiley.
About your NOS1a/G3 ... please check your in-space email. I think I am waiting for an answer there.
Page created in 0.012 seconds with 19 queries.
