« Reply #390 on: November 18, 2014, 08:36:40 pm » |
To change the subject a little, now I´m going to watch on tv the "friendly" match between Germany and Spain to see if we have changed somewhat since the last disaster.  Juan
« Reply #391 on: November 18, 2014, 08:41:02 pm » |
Juan, I don't think I understand unless you don't want the other connectors and have some "discount". So it's the whole bunch for 250. Now you can always see how far you can come with it. This gives me the sort of feeling that *I* did right (with the notice that I really can't stand it that I can't arrange for it really from here). Best regards, Peter PS: To change the subject a little, now I´m going to watch on tv the "friendly" match between Germany and Spain to see if we have changed somewhat since the last disaster.  Haha, as you will know we already went the other way around.
« Reply #392 on: November 18, 2014, 08:58:57 pm » |
Thanks Peter, I´ll concrete the order by PM We will try to avenge the Dutch defeating Germany  Juan
Arjan
« Reply #393 on: November 18, 2014, 11:02:16 pm » |
Hi all,
One word: WOW! The NOS1a 75B with Blaxius cables (180 cm) is the best. More energy, bigger soundstage and lot of real bass. And the highs are smooth.
I already used a bnc cable with adapters, and that was a nice step up. But this is another big step. I sounds Great!
Yesterday the DAC was upgraded. Already direct out of the box and almost cold it was clear to us (me and the family) this is a winner.
Last weeks I did some acoustical treatments with absorption panels. That solved some issues with highs and reflections. But we also lost some dynamics and energy. That is all back now and even much more!
If you have the possibility get this upgrade! It is a bigger step up then I expected.
The sound is now almost at the point I hoped for. Still some tweaks to go, powercords and speakercables.
Regards, Arjan
« Reply #394 on: November 18, 2014, 11:43:02 pm » |
Hi Arjan, how do you connect the Blauxius to your Jadis?, do you use a RCA/BNC adaptor or you have modified the amp inputs?
Regards, Juan
Arjan
« Reply #395 on: November 19, 2014, 07:14:53 am » |
Hi Juan, They are replaced by bnc connectors. So it is the optimum situation.
Regards, Arjan
« Reply #396 on: November 19, 2014, 09:09:37 am » |
Thanks Arjan,
« Reply #397 on: November 19, 2014, 09:26:23 am » |
Yesterday the DAC was upgraded. Very very nice Arjan as you are the first with an "other" amplifier and it works out. For others (see quote) Arjan already had the NOS1a (he was actually the very first) so this upgrade concerned "75B". Peter PS: Hey Arjan, I saw a 75B in your sig and noticed that I was a bit behind with it. But as you have seen, my NOS1a is a fake 75B because no "75B" on it.
« Reply #398 on: November 19, 2014, 09:59:52 am » |
Hi all,
Regards, Arjan
So now i will be leaving to get my upgrade!!! Amps are done as well with BNC connectors... Within the hour i have my NOS1 (a) back  Sounds promising
Stanray
« Reply #399 on: November 19, 2014, 12:34:29 pm » |
Yet another question concerning XLR. My monoblock amplifiers are of a symmetrical (balanced) design. The input consists of both XLR and RCA terminals and the RCA's can be changed by a BNC quite simple. The only thing that worries me is that using the RCA (BNA) will involve an extra network in the amplifier that might be detrimental for SQ.  I suppose I should just try it and see if the negative effect of this network will be compensated for by the Blaxius solution or are there other aspects / effects to consider? Thanks Stanley
« Reply #400 on: November 19, 2014, 02:36:51 pm » |
Hi Stanley,
Are you sure that there's an *extra* network involved when using RCA ? I mean, usually itis the other way around.
or
Or you have a fully differential amplifier and internally RCA turns into balanced again and then you are correct (extra network for RCA).
In the latter case it is hard to predict but that network is then for the good cause because it will sustain your amp's internal differential working; always better than shut off half (which I think won't even be possible). Although this is a bit unrelated to the work out of BNC vs XLR, BNC will be the better one because of other properties. Only cancellation of (picked up) noise will not be there (but I don't have that either). One thing, the opamp most probably involved indeed won't be for the better. No idea whether you will notice against the new cable.
When it is the other way around - and your (real) balanced input turns into Single Ended internal operation, then BNC will be for the better because of the further (better) properties. For RCA probably not (but this is a moot thing). So here it now will only be about the cancellation of (picked up) noise. So this part is the same for both situations.
I must agree - not easy to determine in advance when your idea about this network is correct. Sorry ...
« Reply #401 on: November 19, 2014, 03:46:02 pm » |
Hi, I need some help, could someone tell me seeing my speaker data sheet if I can modify the input xlr to use the NOS1a 75B with Blaxius cables?
Please see also de Operating Manual (2. Installation and Figure.3) where there is information about changing the XLR to RCA
Thanks, Juan
« Reply #402 on: November 19, 2014, 04:02:42 pm » |
Juan, no problem at all. Just connect the wires which are currently soldered to those pin 1 and pin 3 together on the inside. What's now connected to pin 2 is the "hot" wire and that goes to the middle of the new BNC connector. The other two (remember, you just soldered them together) go to the "ground lip" of the connector (sticks out to the side). Just save this text for when you are up to it ...  Peter
« Reply #403 on: November 19, 2014, 04:11:49 pm » |
Thank you!! Peter. Does it mean that I can use the 75B upgrade with all the benefits the same way as others with RCA amps?
Regards, Juan
« Reply #404 on: November 19, 2014, 04:16:45 pm » |
Yes Juan. As far as I can see you will only lose that noise rejection, if important at all. But find that electronics shop for your NOS1a of course.
Regards, Peter
