April 06, 2025, 06:19:45 am *
Author Topic: Orelo MK-II Imaging  (Read 32971 times)
« Reply #15 on: August 21, 2014, 08:27:24 pm »
It would be interesting to get some Details about Daniels audio system.
Kind regards
Dantana
« Reply #16 on: August 22, 2014, 02:38:35 am »
Hi Joachim,
  I have a feeling this is coming. I just managed to update my Signature as it took me quite a while yesterday to successfully send in my post.
Daniel
XXHighEnd PC
i7 3930K Hyperthreading On (12 cores) @0.43GHz, 16GB, Windows 8 Pro 64bit on SSD (ext batt. powered), XXHE on 4GB RAMDisk (IMDisk), music on OS SSD & LAN, DVD Drive power removed, USB 2 & 3 bios disabled
1.186i (Apr 15, 2015*)
Engine#4 Adaptive Mode / Q1/-/3/4/5 = 6/-/1/1/1 / Q1Factor = 1, Dev.Buffer = 4096, ClockRes = 1.0ms*, Memory = Straight Contiguous, Include Garbage Collect, SFS = 0.32*,max 120 , not Invert, Phase Alignment Off, Playerprio = Low, ThreadPrio = Realtime, Scheme = Core3-5, Not Switch Processors during Playback, Playback Drive 4GB RAMDisk (IMDisk), UnAttended, All Services Off, Keep LAN - Not Persist, No WallPaper, No OSD, No Running Time, Minimize OS, XTweaks : Balanced Load = 43 / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On, Double-Octo Custom Filter with Arc Prediction Upsampling, Driver v1.0.3 (2ms)
XXHighEnd PC via USB3 (Silverstone EC04-E, isolated*) > Clairixa USB cable* > 24/768 Phasure NOS1a async USB DAC > XLR > Soulution 725 Preamp* (XX vol. -6.0db)> Soulution 711 power amp > Magico M Project
« Reply #17 on: August 22, 2014, 12:00:01 pm »
But despite all the positive things mentioned above, there was a slight lack in bass quantity compared to what I am used to having in my system. Moreover, there was a veil to the overall presentation. The clarity and transparency was not quite there.
Hi Daniel,
congratulation for your system. These components are well known to be “very fast” and for its micro- and macrodynamic capabilities.
I was a little bit astonished to read that the Q5 (http://www.stereophile.com/content/magico-q5-loudspeaker-page-4) produces more bass than the Orelo MKII, because I felt that the bass in Peters room was exceptional (in the year 2010).
Your opinion confirms that the acoustic of a room has a major influence of an audio presentation.
Kind regards
« Reply #18 on: August 22, 2014, 02:04:28 pm »
Joachim, that's a very nice one, since you don't know that we were especially discussing *that*;
My opinion : not true at all once we can prove that the loudspeaker is doing it on its own. And this is exactly what I tried to do. But mind you please (also Daniel) : this was in the realm of nothing much really working, although I did not realize it myself at the moment of me laying it out; this only became clear when I played the drumming track, "knowing" that it would 100% show the room where the drum kit is in, which appeared not to be working at all. Not this time - not with this "W7 setting".
What is also not in Daniel's post, but was explicitly discussed, is how any perceived high volume of bass is actually distortion. Of course, for me this proof was easy, but it is/was hard to lay out because I can not compare with a "normal" speaker. But, we did some tests and possibly that did not come across. On the other hand, no discussion about another one's observation and I obviously asked for a reason to be honest. And so it was (but we must be careful to not leave out contexts).
Reading that Sterophile review ... I will try Little feat tonight. And I already recall that this track is in my Demo Gallery just because of that.
Wink
vrao
« Reply #19 on: August 23, 2014, 04:47:06 am »
Hey Mani,
Just as a side note, donno why, I myself ended up with all red, but I'm in a phase of all electronic electronic music, and things have changed for other genre, I've not kept a tab about.
I'm just glad so far it has worked out so far with the FM curves. I'm actually having an conflicting experience myself here. Of note, it's peak to end summer here, and it's hot, and many in my locality (May be all) have their AC on, and the line may not be stable. So there are times late evenings when found bass to be phenomenal (+2.2 dB now), to next day afternoon, to WTF nothing there ...?! So that might help?
BTW, FM curves do help with secondary reflections for stereo.
Dan,
My experience with class AB SS amps is that they do have a bit of emphasis in presentation in the upper bass, it might not be distortion, but, just emphasis. I've not listened to SOULUTION  amps themselves, but many, many in its class.
VJ
« Reply #20 on: August 23, 2014, 09:51:28 am »
So much for Litte Feat's Waiting for Columbus. I think Stereophile talks about LP (MFSL ?) while I only have the normal CD and no running through a drum kit is there at the start of the album/performance.
« Reply #21 on: August 23, 2014, 12:02:10 pm »
I always like to reason out what's really going on when people have perceptions which can't agree with my own. Daniel will know I already tried, actually no different than I would do on this forum. The forum is more "easy" so to speak because people could take for granted what I say. Still though, I always try to support my "statements" (if I ever have those) with logical reasoning. I am going to do the same here too, with for Daniel the knowledge that it really is not different at all from what I already told him while here, and the fun, this was without my knowledge of his speaker, let alone that I could implictly have referred to that Stereophile review. The more speaking the below should be. Well, that's what I hope.
Let me first tell that I know John Atkinson and he is no fool at all. If he says that a speaker doesn't have the punch etc., it is so. BUT, you'd have to know that he knows what to listen for in order to make such judgement. Like he in there refers to rock to show it (from the Q5).
So there we are. The Q5 lacks low while the MKII does too according to Daniel. Where is the contradiction ?
http://www.stereophile.com/content/magico-q5-loudspeaker-measurements
I tried my best to show where low is to be low and where it is not to be that. Thus, reflection to reality. This is a hard thing to do when not knowing the real reality; we should drag in the real basses and such. Still the MKII measures completely flat (+/- 0.5dB up to 19Hz) and now compare with the Q5. What do we see ?
I say Ouch !
If I am as honest as I can be, then I take the avarage "level" between 200 and 6000 Hz and I see a ~2.5dB for that line (with the 0dB line as the reference). This is to be compared with an output at 50-60Hz of 8dB. Uhm, this is 5.5dB More ?!?
If I am less honest (but also more normal) then the average line is at something like 1dB (real rise starting at 300 Hz leftwards) and the difference is thus a sheer 9.5dB.
Are we crazy here ? MKII owners, add 5.5-9.5dB to your bass section and tell me what happens.
But I know, the whole thing will blow itself backwards at a good punch of sound.
Of course, for real comparison only that 50-60Hz area should be boosted. Can be done, but uit will colour as hell.
So ... before we can compare such things, we must first acknowledge that something is the most wrong with the Q5, no matter it may sound very OK. But is it reality ? Well, how can it be.
Now how I read reviews and how you get to learn reviewers :
It is impossible that no notice is made of some superbly high output bass. Well, "superbly" can hardly be in order, but for level it should have been noticed. Still it was not.
But learn to read reviews ...
Where is the distortion plot eh ? It is not there. Why is it not there ? well, me says because it was too poor to show. That is how reviewers work, with the notice they receive gear to review it and no reviewer likes to express badly about that gear because it relates to manufacturers which are people. And why bash on people. Still, what's left out is the explanation how bass does not come forward. But depending on how smart you are (as the reviewer) to leave out things, OR put in things to show you are sure not lying. And while discussing the exact same matter over here last week, this is what I explained :
Any not high passed (for LP) recording, will show a kick drum at ~38Hz that "rolling" all the way to about 20Hz. And this is not the (my) room doing it, because measured from a 2cm distance. It is that (very) low end where the kick in the stomache happens, obviously. Also : A high passed recording will not show a thing of it. Remember, same speaker of course. It's just not in the recording.
Now again look at that plot, and know that any John Atkinson (or me for that matter) *first* seeing that plot, can next see what type of music will work out, and what will not. Also, and this is crucial, envision what the volume know will be tuned to with such a speaker; It will be that 50-60Hz because it is the loudest part. Also (and also crucial) this is where many instruments play. The electric basses and such. And also : this is how the speaker will sound very smooth because the low frequencies will mask the higher ones to a large degree. It's 5.5-9dB higher you know, and this is so much that ... well, what to say.
Anyway, now any electric bass or higher keyed upright bass (up to cello) will be very profound. Nice (but never even for the whole range of the instrument - obviously).
Once you know how the speaker (or the whole lot) measures, you can see that no kick drum (~38Hz) will excel or jump out in the first place because it is 6dB lower than that nice bass playing. So there it starts. Next though there's a very steep roll off and it is right in the area the kick drum likes to play (as said up to 20Hz and this goes in flat fashion !).
Look again at the review; "rated to 29Hz" (similar). Yes ? NO! It is 29Hz if it is related to my mentioned avarage ! Thus, it is 29Hz compared to anything playing in the 200 - 6000 area. It is not 29Hz at all when related to 50-60Hz. And so the bass playing in that 50-60Hz area (but you can make it somewhat broader) is completely masking any kick drum.
And I say it again, only MKII owners know what a difference of already 1dB brings in that area, because it really comes out. Not so with a speaker like this because it will only distort (and I guarantee you that). So instead of the energy given to for example 30Hz it will spread to harmonics like 60Hz (and 90Hz and so on). It is just a stupid fact that it works like that, once you see the plot going as it does. Compare with the MKII's if jou like with further the knowledgs that the super steep roll of beyond 19Hz (leftwards) is there to prevent any 18Hz etc. from turning into 38Hz etc. This is also how the plot gets super straight, would you put up an 18Hz or lower signal and observe what's happening higher up.
If you're almost satisfied with my description of matters, let me also tell you that this plot is highly averaged to maybe 1/2 of an octave which is quite much of averaging. IOW, would it have been done like my plots do (1/12th) than the peak at 50-60Hz would even have been higher and the whole plot more of a mess. Compare with the plot under it where the comparison with the Wilson is made. Even that is already averaged to 1/6th.
Reviews ...
More back to the beginning of this post and my always telling about how distortion fools us :
That low end will show super high distortion. Probably so much that J.A. did not want to show it. But, he justifies that by means of "text" and tells you that you better shouldn't play Rock. But what happens - and I showed that while Daniel was here - is that any distorting low frequency is perceived as an even lower one. You see this happening when a nice sine of say 30Hz is (synthesized) into a more square tone. So first you hear a low sine indeed and which is just perceived by us at a low level because we are not able to hear such low levels so well, and when the harmonics of it (that's what square does) jump in, the first what happens is that we perceive that beter, thus louder. And you know, there is no difference between a sine which is synthesized into a square and a sine which is receiving odd order harmonics because of not being able to do it and thus distorts. It's just the same.
What happens here is different from what I talked about earlier in this post because now any distorting 50-60Hz which is at a too high level to begin with (that 5.5-9.5dB) will show harmonics and you know what ? they are at a lower level (it is just spreading of energy). Now we could say that the Q5 has been designed very smartly, because this blends to a perceived somewhat same level. Think of my often given example of 24Hz we can just hear, and when this distorts you hear 48Hz only and this is only because we perceive 48Hz better than 24Hz. But do this in a smart fashion and the 48Hz will be as loud as the 24Hz. And now you have a nice blend of the both and you think the instrument sounds like that.
Well, I better stop. And anyway, whether I am right or not, this was all already discussed when Daniel was here and then undoubtedly could have come across as stupid theory only. But with now the measurements of the Q5 at hand, I think I did not lie a thing and theories are not so much theory.
Whether this all leads to a better accepted sound (or music) is something else. At least I know with a year of experience with this, that this doesn't bother me at all. The contrary, it is for the better. Sadly though examples exist of things "working" with a normal speaker, now not working any more and this is only because the recording engineer "utilized" the distortion in a speaker to produce the recording. I showed an example of that too, just nothing audible while my old fine speaker showed shaking Whooosh. Now though it appears that the frequency is so low that we can only feel it. Bad luck for that particular track.
« Reply #22 on: August 23, 2014, 02:59:12 pm »
I like to add one thing to this all, outside of feeling that it can have come across as a sort of self-defence (it is not, and I am not saying one thing different from what I'm always saying) :
In my observation Daniel has very good ears. I hope I am allowed to say that. Or maybe put differently : he was better able to discern culprits than me from my own known system. With this in mind ...
Or maybe a little bit more of toe-in?
Now, we dit NOT talk about this subject at all. But it is spot on. It is also right on topic for our "Imaging" topic here. Let me explain, and MKII owners, be "advised" ...
Up to the lowest frequencies the bass from these speakers is "pure directional". And no, I don't recall that Daniel and me were playing something that would show it (at least I did not for the purpose), but possibly he noticed anyway, and this is related to the quote above;
What I do on purpose is not let blend the bass where I observe(d) it shouldn't. Now, with 0.00 degrees of phase difference between left and right (all NOS1(s) owners have this), this means that any not exactly same initiation of left and right of bass will create a hole in the middle.
Now, sorry to be technical, but because of "electrical" reasons almost all recordings show that not being equal of left and right (for when the sound emerges from the speaker). Let me try to explain by means of the NOS1(s) itself (but I have told this in particular before) : Any common DAC will have a phase difference between left and right of about 0.02 degrees. The NOS1(a) can do this too ... just set Switch#5 up and deactive "Is NOS1" in XXHE Settings (or use another random player).
The difference between these two settings ?
No single whatever bass will sound from one speaker only never mind it really does. Actually it is so that nobody will notice really and notice that it should be tested with the "sine" like sounds only, or otherwise the higher frequency harmonics will discover the real positioning (and now you are fooled and only with good experience you will hear that the bass still comes from the middle).
The difference is only 0.02 degrees (at 1KHz btw and for a lower frequency it will even be less) but it is totally crucial. So is the distance from the two speakers to you - just saying).
What do I want to say ?
Well, that this same difference is for similar reasons how a normal DAC operates, there for the same electrical reasons. Thus, it is almost always there. What does this mean ? ... that no bass will sound from the middle because there's a small difference (delay from left to right or the other way around) that will imply "space". Just think that with DSP you will overdo this and the result is a spatious sound. BUT :
When you allow the both LF beams to merge too much, the effect goes away. Also - and very logically, with the base of the both beams having merged indeed, they will add up fully. Result ? more bass.
Aha.
Aha, because I deliberately prevent that. How ? Toeing out more.
Aha aha.
As an intermezzo I can tell it form a different angle :
This effect - of the both channels not shooting at the exact same time - is so strong for the lowest ferquencies, that the air pressure in the room fluctuates because of it. Easy enough to understand : the SPL is now oscillating with the two beams which don't fire at the exact same time. So normally there's the one frequency only (say 30Hz) and we are used to that, but when the one 30Hz follows the other 30Hz there's actually a distortion going on. And some people are sensitive for this. They go literally sick (and I really experienced that here although it was not me myself). Remedy : Toe-in.
When a woofer is distorting to begin with, there are so many frequencies in order that what's thrown at you becomes more random and the "sick" effect stays away.
I am not bothered by this effect, but *I* am bothered by the uninteresting sound coming from the speakers otherwise. It then just "does not work" any more.
So about the imaging : Try to perceive a bass from the middle to begin with (find the proper recording). Works ? Then now toe-out. Say that you move backwards the outer wing tips for 3cm each. That should do it.
If all works as it does here, you now will perceive that hole in the middle.
Really intended or not, this is how it's in the recording.
But watch closely;
You might have perecived this before and think it is no good. Most easy thinking is that it is the high frequencies doing this to you; but it hardly can because you're listening off-axis to begin with (on purpose, since the mid-high horn is above you); so, the "on purpose" is about the toeing you can now do to your liking because the nid-high will hardly impact because of on-off axis listening (it will for reflections to the side walls, but this is another matter). Thus, concentrate on the bass because it is all about that.
Less bass, but separation in it. Do call it DSP if you like. But if all is right something now starts to "work" which otherwise could not be there at all. It is the left/roght (very fast of course) movement of how the waves emerge form the woofers. It creates spatiousness.
We could say that Daniel was thus spot-on with his idea about the toeing in with the notice that we didn't try a thing with this because it wasn't brought up as a subject. But I know ... it will work. For more bass that is. Not even about more perceived bass but about it really being more (the adding up). So blend it too much and it will happen.
And I do it the other way around on purpose ...
Small disclaimer : I highly doubt whether it would have brought much difference with my Windows 7 which is not accurate in the bass at all ( way way too thick for how I DSP'd the speakers which has been done for Windows 8 ).
Anyway, MKII owners should try and I think it can be a revelation. Very easy to try as well, so let me know your findings ...
« Reply #23 on: August 24, 2014, 10:14:59 am »
Not specifically about the imaging, but after going back to W8 yesterday I again noticed the super clear difference between W7 and W8 at feeling the woofers :
With W8 you feel exactly what you hear.
With W7 you don't feel at all what you hear; by now I appreciate this is one big pile of distortion, which is also how it sounds.
Page created in 0.017 seconds with 19 queries.
