November 23, 2024, 03:45:37 pm *
Author Topic: New filter: error message  (Read 17833 times)
« on: June 23, 2014, 05:56:13 pm »
After a play command i get the following message : <failed to set sample rate> after accepting this message i get the message <xx engine 3.exe has stopped working>. What did i do wrong.
I have first selected  the preselection 70560 APon| 23800 preferred filter. With activated <Custom filter>
Johan
« Reply #1 on: June 23, 2014, 06:11:39 pm »
Hi Johan,
This must be unrelated to the Filter.
Can you easily prove that without changing anything else, switching between Custom and AP (and back) does not behave the same regarding this message ?
« Reply #2 on: June 23, 2014, 06:52:18 pm »
Indeed AP gives the same message.
Any suggestions?
« Reply #3 on: June 23, 2014, 06:57:55 pm »
That is something ...
Nothing different from when this happens in other situations ?
Most obvious would be that you deactivated "Is NOS1".
And always kill the sound engine (blue led) after such a thing happened; that assures that a next attempt won't go wrong because of some anomaly in the previous.
« Reply #4 on: June 23, 2014, 09:36:29 pm »
After a restore of the original files i got a new message Settings Preset File in use was corrupted. After loading an older file all was working again. Placing the new filter files all works. First impression sounds goood!
Regards Johan
« Reply #5 on: June 30, 2014, 06:03:14 pm »
Today again (not related to the new filter!) a new error message "allocate Kerner streaming audio device" - Devide allocated but can't play. Check dac settings, applied sample rate- After ok i get a message 4/32/768000/12288000/16.
Reset the system and start again xxhe the following message appears <failed to set sample rate>. The only way to fix this error is to load in the xxhe setup an older preset file.
Any suggestions to prevent this sort of errors?
Best regards Johan
« Reply #6 on: June 30, 2014, 06:13:58 pm »
Johan,
Most probably this is about mixing preset files in the first place, but actually anything can happen once in a while with the presets. But this is how the auto-backups (each day) are there now. So good that you find those.
Since this version I encountered one single occasion (wel, that I have heard of) who needed the backup similarly to your needs for it, but in your case something else must have gone first earlier on (something with the install). But I would not bother about that (not any more).
Still the last error you reported is to be observed for happening again, because if now suddenly your presets get corrupted all the time something else is wrong. But here too, not to worry. Not yet; we can always worry later when it appears necessary. Ok ?  Happy
« Reply #7 on: June 30, 2014, 07:09:15 pm »
Hi Johan,
Are you even sure that the Audio Device (in XXHE Settings) did not change to the HiDef or whatever Audio Device ?
« Reply #8 on: June 30, 2014, 07:10:28 pm »
When all was running again well, I switched back to AI, again there were errors about failled to set sample rate. Loading again preset file and all is working again. Grrrrrrrrrr back to AI now working!
« Reply #9 on: June 30, 2014, 07:12:20 pm »
How can I check this?
« Reply #10 on: June 30, 2014, 07:24:16 pm »
Just check what is in the Output Audio Device in XXHighEnd Settings ...
« Reply #11 on: June 30, 2014, 07:25:38 pm »
I have seen this behaviour earlier music stops just before the end of the track and start the next track! All tracks!
Q5=2, Q's=1; others 1; sfs=0,4
« Reply #12 on: June 30, 2014, 07:26:47 pm »
Unattended ?
« Reply #13 on: June 30, 2014, 07:27:46 pm »
Yes
« Reply #14 on: June 30, 2014, 07:30:24 pm »
You said with AI. This was no mistake ?
I mean with Custom this can happen.
OK, with AI too, but now better raise about all "SQ" parameters because of the size of the files (which are huuuuge).
Page created in 0.129 seconds with 19 queries.
