November 22, 2024, 10:52:25 pm *
Author Topic: Engine#2 needs the Primary Device  (Read 8973 times)
« on: May 31, 2007, 01:34:12 pm »
Please keep in mind that Engine#2 kan operate the Primary Device only (as set in Windows Sound Properties).
If another device is selected, there will be no sound.
Note that XX implies that you can select another device for Engine#2, which is wrong and will be removed in a next version.
If you are not sure which device Engine#2 will be using : click the combobox at the top, and look for the first device listed.
