April 08, 2025, 07:05:09 pm *
Author Topic: Set State (Pause) error on pin  (Read 8474 times)
« on: June 07, 2014, 09:28:45 am »
After switching PC-power off/on, XX will not play. It starts the process, recognizes the file format (f.ex FLAC), but then it halts and shows error message "Set State (Pause) error on pin".
What to do?
« Reply #1 on: June 07, 2014, 09:31:22 am »
Unplug/Replug the USB cable ?
And if that does not help switch Off/On the DAC.
« Reply #2 on: June 07, 2014, 09:41:24 am »
The latter usually helps when I encounter this error. The physical usb connection is rather sensitive, only toutching the wire may cause it.
When I switch the NOS off I wait for a minute to repower it. A protective habit from the early PC days.
Regards, Coen
Regards, Coen
« Reply #3 on: June 07, 2014, 10:06:34 am »
Just re-booted the PC and now it works again.
Thanks for helping, guys!
Page created in 0.013 seconds with 19 queries.
