November 23, 2024, 08:47:46 am *
Author Topic: Bert von Orelo?  (Read 10943 times)
« on: May 20, 2014, 10:22:54 pm »
These speakers looks somewhat familiar:
http://vinylsavor.blogspot.com/2014/05/high-end-2014-room.html
Regards,  coen
« Reply #1 on: May 24, 2014, 12:20:38 am »
Just trying to bore every one with a link to another copycat:
http://audio16.wordpress.com/2014/05/17/impression-from-the-munich-high-end-2014-i/
(Middle loudspeaker of unknown manufacture)
This time not an undersized horn, but an amt (i think).
Regards, Coen
« Reply #2 on: May 24, 2014, 06:40:40 am »
That should be the Backes & Müller I think. And well, at least that one looks good. The Von Langa ? hmm.
The Von Langa (not the very same version) emerged around the same time as the Big Orelo. Maybe the NSA threw some designs to the respecitive creators. Wink
Backes & Müller ? Not sure whether that's a commercial speaker (yet). But I never saw it before.
Thanks for sharing Coen.
« Reply #3 on: May 26, 2014, 09:05:51 pm »
There is no substitute for square meters of loudspeaker surface when you're after a loud and low distortion bass. If you want it fast and clean you need an Open baffle (or giant horn), it looks like a natural evolution of speakerdesign.
Both loudspeakers probably cross over at 1.500 Hz or more with the little horn and ribbon (AMT?). There must be a compromise in the midrange. No doubt the field coils in the WvL will sound very fast and competent in the lower mids but keeping up to that high...
Regards, Coen
