November 23, 2024, 05:29:29 am *
Author Topic: The 5 switches...  (Read 10121 times)
« on: May 17, 2014, 08:43:16 pm »
I forgot about these buttons since long time ago. Are they I correct position? (See photo from present settings).
« Reply #1 on: May 17, 2014, 08:58:57 pm »
Hi Pedal,
Yes it is correclty set for 705 and 768khz potentially Happy
Edit: from right (in the picture) to left: the second is turning the DAC ON and the leftmost is for the 705-768khz when as you have it, or for "Stereo reduced" when down...
« Reply #2 on: May 18, 2014, 09:33:02 am »
Allow me Alain ...
or for "Stereo reduced" when down up...
« Reply #3 on: May 18, 2014, 10:01:47 am »
Ok, why not mention them all. From right to left (see picture) with the notice that down always is On :
1. Display.
2. Power to DAC section (unrelated to power supplies and USB).
3. Not used.
4. DC Offset Check (metering in the left leg). Needs 9V battery to be connected.
5. 705600/768000 input. Windows only and when player supports it (XXHighEnd, HQPlayer).
« Reply #4 on: May 18, 2014, 01:59:47 pm »
Hum... Why not precise that the numbers start from the nearest button when you face the NOS1 Wink
By "down", I meant that to activate something, you have to press the button down...
Different perceptions I guess...
Edit: Ah... Sorry Peter, now I realize where the "down" was out of place.
« Reply #5 on: May 18, 2014, 02:28:26 pm »
Hum... Why not precise that the numbers start from the nearest button when you face the NOS1. Wink
Hum hum ... they do !
Sw#1 is the one most near to you.
Hum hum Ahum haha
« Reply #6 on: May 18, 2014, 04:01:41 pm »
Of course, I was "cleaning my throat" by that "Hum"... I have had enough "Hum" (as in ground loop) last year Wink
Alain Happy
