April 06, 2025, 11:52:58 pm *
Author Topic: XX High End doesn't stop (all versions)  (Read 9419 times)
jsa
« on: December 02, 2007, 01:54:17 pm »
I am still using your XXHighEnd in the demo mode. When using it via motherboard SPDIF - if I press STOP button or just close the program - last 2-3 seconds of sound are repeated forever. I have to restart the computer in order to get rid of it.
Since it is demo mode if program exits automatically effect is same as above i.e. last 2-3 seconds of sound continue to be repeated forever.
If I play the playlist to the end no problem whatsoever.
Can you check why could that be?
It applies for all versions that I have tried (09-r, 09-s, and older versions as well).
brgds
Jurek
desktop on mobile processor Pentium T5500, motherboard Asus N4L-VM in Antec NSK2400 case -> various options tested currently : EMU0404PCI/PSAudio Digital Link III (usb DAC)/Benchmark  DAC1USB/ direct spdif from motherboard -> DAC CEC DX71mkI
« Reply #1 on: December 02, 2007, 03:07:47 pm »
Hi Jurek,
I guess you -somewhere- have a large buffer, assuming this happens with all the DACs you tested (but you have it with SPDIF only ?). Anyway, this 2-3 seconds is longer than I anticipated upon (according places in the program), so indeed now it can happen.
I will make it longer.
« Last Edit: March 15, 2009, 08:58:40 am by PeterSt » Logged
jsa
« Reply #2 on: December 02, 2007, 03:29:29 pm »
Confirm it happens only with onboard spdif out.
Great that you will correct it. Many thanks. Much appreciated.
brgds
Jurek
« Reply #3 on: December 02, 2007, 04:08:42 pm »
It's ok Jurek.
To me the 2-3 seconds seem crazily long. If you can find a way to set that shorter (merely to 1ms or so Happy I think that will influence SQ for the better.
Note that I'll adjust it anyway, so it's not about that.
