« Reply #75 on: July 21, 2014, 11:33:36 am » |
You are the single only one I never confirmed. Probably this is because you never responded to my email in the first place. Haha. Sorry, it was not intentional, for sure . Good to know that i'm in the list. Best regards, Nick.
« Reply #76 on: August 21, 2014, 11:06:57 am » |
Small update again :
I must say, things got way slow on our side suddenly;
To my own surprise, last week I found myself ordering parts for the next 30 (first round was 25). Not that all first 25 resulted in 25 NOS1a's (some boards fail) but still close to that. Partly the first batch of parts was consumed by new ones (remember, they have priotrity) and this is hard to plan of course.
What happened next though, is that *because* we ran out of parts, we also ran out of the half products (the soldered PCB's etc.). And what I did not much take into account is that while the first real produce was "postponed" by final trials and waiting for trial parts etc., meanwhile those PCB's could be produced in advance. But since we ran out of these, they now have to be produced (say first, in larger batches). Of course I never thought of that as the first production of these went quite unnoticed (OK, for me - not holding that soldering iron). But now ? yes, now I notice because it is a week of work going on already per today. And not finished.
Thus, might you get the feeling "when is my turn finally !?" then you should know we did not forget you.
Stanray
« Reply #77 on: August 21, 2014, 03:13:30 pm » |
The longer the waiting the sweeter the kiss
Rob181
« Reply #78 on: August 26, 2014, 05:55:56 am » |
Peter...
As a matter of interest...what number of upgrades are you up to...I know I am number 25 & I am trying to plan roughly when to send the Phasure back to you...
Thanks...Rob
« Reply #79 on: August 26, 2014, 08:39:53 am » |
Hi Rob, 10 ahead of you at this moment. Regards, Peter
Rob181
« Reply #80 on: August 28, 2014, 11:58:38 am » |
Thanks for the update...sounds like it may be ready by Xmas with any luck...a nice present for myself...Rob
