November 23, 2024, 09:51:51 am *
Author Topic: Engine 1 turn red, and stop playing  (Read 5831 times)
topline
« on: December 01, 2007, 02:13:30 pm »
Hello
Have a problem with engine 1 in XP, usb.audio.dac out. It plays a few track before it stop, and the engine shows in red. Sometime it's ok with flac but not with wav files. Whats wrong??
« Reply #1 on: December 01, 2007, 03:22:01 pm »
When "#1Engine" shows in read, it indicates that you chose Engine #1 to play with, but instead XXHighEnd switched to Engine #2 because #1 could not cope with the file size (which is limited to (uncompressed) 64MB).
Now, when the sound stops right at switching internally to Engine #2, it means that most probably you did not set your Primary Sound Device to the one you actually chose for playback with Engine #1. Note that with #1 you can choose from the list of devices, which #2 does not allow (it always takes the first listed (actually the second, because the first one is mentioned as "Primary Sound Driver", being the one listed right underneath that)).
I hope it is not too confusing ...
Page created in 0.143 seconds with 19 queries.
