November 22, 2024, 12:46:37 pm *
Author Topic: Unattended not working  (Read 13969 times)
0 Members and 12 Guests are viewing this topic.
« on: April 22, 2014, 10:19:11 pm »
Dear Peter,
My media-PC is connected to my WIFI router, and I control it from a laptop with Windows Remote Desktop software (RDT).
My XX is activated of course and running in "Minimize OS mode".
It works perfect, except that I am not able to use Unattended playback.
When trying for Unattended, I lose the RDT connection and XX seemingly shuts off. No sound/no playback.
What to do?
« Reply #1 on: April 23, 2014, 02:58:41 am »
Hi Pedal,
I have seen this sometimes, but not sure... Is it possible that some Windows updates have passed through ?
« Reply #2 on: April 23, 2014, 07:51:07 am »
Hi there Pedal,
Maybe you changed something in the "shut off services" section ? Most obvious would be "Use Remote Desktop" of course ...
« Reply #3 on: April 23, 2014, 09:08:19 am »
Thank you, Alain. However, the control panel says "no updates installed" on my Win8 Pro.
Pls see below screen print of current settings: Any clue here?
« Reply #4 on: April 23, 2014, 09:14:13 am »
I assume you had this working ?
I mean, so something must have changed ?
« Reply #5 on: April 23, 2014, 10:25:10 am »
It worked in W7, but never in W8. (PC and hardware is exactly the same since 3 years).
The RD (via laptop or iPad) works perfect as long as I don't use Unattended.
1.
Screen shot: Loading a single 16/44 song and trying for Unattended playback with present settings; SFS = 0,2.
2.
Changed SFS = 100 and tried again for Unattended playback.
3.
XX gives me a "wait for services on top" notice, as is normal.
4.
The RD lose contact with the PC (as is normal). But no music...
5.
When re-connecting with RD I find that XX is turned off and I get this small error message at the far bottom right; Photo #2. (This message appears ONLY when logging on to the media-PC AFTER an failed Unattended play attempt).
« Reply #6 on: April 23, 2014, 11:09:23 am »
No it does not (should not) but maybe you think it does somehow.
Not sure whether this can be key to the problem.
The message in the bottom left corner is normal, although it tells me that you had to log in again ?
Try it on the music PC itself directly. It is my guess that the same will happen. If so it is Windows Defender bugging you.
But let me know so I can give you a solution for that.
« Reply #7 on: April 23, 2014, 12:42:12 pm »
Yes, you are right. I mixed up some old memories.
Try it on the music PC itself directly. It is my guess that the same will happen. If so it is Windows Defender bugging you. But let me know so I can give you a solution for that.
OK, your prediction was correct: -I hooked up mouse, keyboard and screen and tried Unattended playback. Still the same problem.
Not only XX being shut down, but also another program (Windows Paint) was shut down. Also, I had to log on as a user with password to get back into the PC.
Once, I was thrown out of a discotheque for doing something nasty. It seems XX is being kicked out too, when trying to do something impropriate (Unattended playback)   Grin
« Reply #8 on: April 25, 2014, 09:21:49 am »
Pedal, I am sorry, but I completely missed this last post from you.
This is what Anthony said in the other thread :
Go to Control Panel > Administrative Tools > Services > Windows Defender and stop it and disable it so it does not  start again when you reboot.
But I doubt whether this works. And NOTICE everybody, some PCs (OS installs) are easy on this, some are not at all. So Pedal, can you try the above and let us know whether that helps ?
When it does not help, try this which surely works :
Go to Start - Run - type gpedit.msc
Expand Administrative Templates (under Computer Configuration) and expand Windows Components.
Click Windows Defender and on the right hand side double click Turn off Windows Defender;
In there activate the "Enabled" radio button and click Apply.
Reboot is not necessary.
« Reply #9 on: April 25, 2014, 09:25:51 am »
Come on now. But better be careful to not to be thrown out of your own house.
Hey, I was once thrown out of a church for doing something nasty.
yes
« Reply #10 on: April 25, 2014, 06:20:25 pm »
You were correct. It didn't work out. At least I couldn't find any "off/disable" buttons.
This DID work!  Happy
Unattended is playing.
But now screen is black and out of control until song(list) ends, so I gotta try to recall how to use the Hotkeys again!  smile
« Reply #11 on: April 25, 2014, 06:31:04 pm »
Thank you for this feedback Pedal !
Haha - you're talking like you didn't use Unattended for a very long time ?
But in case you did not find it yet, here : AutoHotKeys (Remote Commands) Listing.
