April 04, 2025, 09:42:52 pm *
Pages: 1 2 3 [4] 5 6 7 8 9 10 11  All
Author Topic: New Filter request(s)  (Read 157308 times)
« Reply #45 on: June 22, 2014, 09:49:59 pm »
Hey Peter, the Custom filter is totally phenomenal. Only now can articulate what I've thought about AP for so long. There's a certain 'nervousness' in the extreme HF that gives an edge to the music. Initially, it might even sound appealing. But after switching to Custom, you realise how much more natural the sound can become.
Thanks so much for listening to 'us' and pursuing this for us. I'm sure you've put it quite some hours on this... Well, let it be known that your hard work is much appreciated.
charliemb
« Reply #46 on: June 23, 2014, 01:45:48 am »
 sounds good ! love this very happy thankyou dancing clapping good
July 2019:
charliemb
« Reply #47 on: June 23, 2014, 02:09:08 am »
Fantastic and very musical filters.  Thanks. You can tell I'm very happy from my previous post.  I'll have a hard time picking a favorite between custom-176/192 and the new AI.  Over here it is majorly different from before, for the better, and I'm running 4x only with an "open dac" meaning using the simple filter that has slow rolloff.  So slow upon slow.
One problem I must report about AI:  AI is not multitasking as I expected from reading your previous posts.  I only see one yellow CPU-core light and albums load slowly as before.  Example,  one Spiro Gyra album has 8 tracks with all tracks nearly 5 minutes long, and the longest track is 5:49.  Well AI prodded through these 8 tracks one by one and I timed it with a stop watch.  This album took 2:09  sleeping to start playing.
You can see my PC specs below.  This is a fast xxHEPC and I'm running it at 2.5GHz; I don't use playback drive.
One thing that could be causing this is my AI settings.  I have the pre-post ringing set to 17% and I use dither set to "noise shaping."
Why is the new AI so slow at loading?
July 2019:
charliemb
« Reply #48 on: June 23, 2014, 02:25:59 am »
One other problem with AI:  hitting alt-N during unattended playback causes "DAC can't play... check settings.." (I think it's that one).  Hitting alt-P does not resolve the problem.  I need to hit alt-X and hit play button for it to play again.
The shortest path to getting to the next track is to hit, while a track is playing in unattended mode, hit alt-X, alt-S, select next track and click Play.  Well, at least that works without ever getting error.
So hitting alt-X appears to be the key.
July 2019:
« Reply #49 on: June 23, 2014, 08:24:41 am »
Hi Charlie - Thank you for all the feedback.
But it sure is, unless I eliminated it all because of other issues I ran into. So I will re-check !
But 2:09 for a whole album ? seems quite impossible to me (if track per track), although I don't really have the reference on 176/192.
Please notice that I regard AI a dead end. It is in there because I started out with improving it to later come to the conclusion that it is and remains akward (and slow). So representatives of it will be built onder Custom. But, takes time of course.
I will check the multi threading.
« Reply #50 on: June 23, 2014, 12:16:17 pm »
SQ of the new Custom filter is more than excellent, even with my NOS1 non a (yet).
I am however experiencing ticks in the right channel on 705.6KHz samplerate. These are related to the level of the music playing.
The music sounds significantly more subtile on 705.6 than on 352.8KHz. Much more like my preferred v8e setup.
FWIW:with the latter sample rate there are no ticks.
Is this still work in progress or should I adjust some specific setting?
regards, Coen
« Reply #51 on: June 23, 2014, 12:52:54 pm »
regards, Coen
Raising SFS helped a bit.
« Reply #52 on: June 23, 2014, 01:33:06 pm »
I myself have the hunch that it is a good idea to kill the sound engine before playback is attempted with a new setting.
I heard ticks too, but when I try to incur for it (so I can solve it) it never happens.
About the volume :
I would not play at -0dBFS with this. So maybe people don't do that anyway, but at this moment the filter is not 100% protected against "clipping".
-6dBFS at least should be OK.
« Reply #53 on: June 23, 2014, 02:07:47 pm »
Thanks Gerard, but no success here. Maybe I have been to conservative  Wink.
regards, Coen
« Reply #54 on: June 23, 2014, 02:20:35 pm »
This does not seem to cure it right away. Maybe I have a still to low SFS like Gerard suggested. I am reluctant with this because some of the magic disappears when raising the SFS here. I will try values above 12MB. Do I recall correctly that the Q1 and Q1x also have to be raised?
I have to note that I heard the ticks right after the 'fresh install' of the filter upgrade package.
About the volume :
General advice taken, though I deliberately never play louder than -6dBFS.
regards, Coen
« Reply #55 on: June 23, 2014, 03:08:47 pm »
made a test with the „Custom“ filter, and what amazing cymbals, detailed with the “clicks” etc.
But overall this filter emphasizes the highs too much on my system.
« Reply #56 on: June 23, 2014, 03:18:39 pm »
Joachim, did you try 16x AP? I think you need to in order for the filter to work properly.
« Reply #57 on: June 23, 2014, 03:35:21 pm »
I wish I knew myself what is going on really. This is a text from someone who doesn't frequent the forum :
  I've managed to play without hearing any more ticks. I've got the SFS down to 1 now, each time hitting the Blue LED as I adjust the SFS lower.
  Now the sound quality is fantastic. More pin point focus, recording ambience is clearly captured, and the highs are simply gorgeous.  It is really hard to imagine what will it be when this new filter is combined with NOS1a.
« Reply #58 on: June 23, 2014, 04:00:03 pm »
yes, the filter works in 16X AP only. The sound (characteristic) of my speakers are from the "bright side". So, bad luck for me.
« Reply #59 on: June 23, 2014, 04:47:23 pm »
Joachim,
If you prefer 8x in general you can also select the 176400 filter (and use 8x).
