November 23, 2024, 10:20:28 am *
Author Topic: "XXHighEnd PC" & 4T Disc Incompatibility  (Read 7660 times)
« on: April 01, 2014, 12:33:36 pm »
I ordered a 4T Seagate internal HDD for my XXHighEnd PC "clone". This is just a note to say that the 4T disc does not fit in the removable slots at the front of the Silverstone GD06 case. It will slide in and connect into the sockets at the back OK (so it will work) but the door covers do not close. This is because the disc is about 2mm longer than all the other HDD's  that I have tried and that fit no problem.
The 4T disc will fit in the internal position inside the case. Maybe not a major issue but I thought it worth mentioning.
« Reply #1 on: April 01, 2014, 01:23:10 pm »
Hmm Paul, how is this related to "incompatibility" and a PC ?
This disks are incompatible !
Investigate 2TB 2.5" for fun and then you will understand (only one brand existED that had them in the proper size).
« Reply #2 on: April 01, 2014, 02:01:32 pm »
Maybe I should have said "Physically Incompatible" well anyway I am sure you get my drift.
« Reply #3 on: April 01, 2014, 02:11:58 pm »
Not so sure Paul. The disk you bought doesn't fit the standards for it and if all is right it is noted in the specs of it.
If you say that your PC is not compatible with the disk then you can just as well claim that all PC's with removable bays are not compliant (yes, I used another word now).
Word games ?
These stupid disks are just not allowed to exist.
