November 23, 2024, 02:20:43 am *
Pages: 1 2 [3]  All
Author Topic: Network Access in Minimised  (Read 44677 times)
« Reply #30 on: March 18, 2014, 09:28:24 pm »
Hi Anthony,
When you used your NAS, did you need to have your drive formatted in a linux format or was it possible for you to leave it in NTFS ?
Hi Alain,
My NAS manages the drives itself so I don't know what format they are to be honest, but it runs Linux so I guess a Linux format.  I use Raid5 which keeps a duplicate of every piece of information on another drive and the drives should be matched in pairs (same capacity) although this is not essential.  On top of this I backup the NAS to another computer on the network which means that I have my info on at least three local drives.
« Reply #31 on: March 18, 2014, 10:03:25 pm »
I have Gbit ports on the two PC's on my network and I have a Gige router and Cat5 cabling. The typical copy speed I get is about 90Mbps (bits). Disappointing as it means there is a fair wait while an album worth of files is copied over before replay starts. The longest run of Cat5 from the router to the XXPC is about 35M which is not very long for CAT5 really.
Unless anyone has any ideas I guess the next step is to get the two PC's close together with a short length of Cat5 (xover) and see what speed I can get. Then if that works I will work back from there.
Anyway any ideas welcome!
« Reply #32 on: March 18, 2014, 11:00:53 pm »
Paul, I don't know how easy it is for you to route some new cable (cat5e or cat6) but the cable itself is quite inexpensive as is the gear to terminate it yourself.  When doing the house here I purchased a 100m roll of cat5e and the tools to do the termination and test the cable for about AU$100.  It is simple to do for a guy of your diy ability.
And you will not need a xover cable to direct connect two computers...modern LAN ports will self detect the connection and adjust accordingly...so you will be able to use a normal LAN cable.
« Reply #33 on: March 18, 2014, 11:11:55 pm »
Hi Anthony - I installed CAT5 cable in this house a few years ago when we re modelled the house and did the terminations (maybe that is why it is slow ha ha!!). It would be impossible to replace the cables now as they are buried in the walls and under the floor boards etc. I will find out why it is slow though -and I still have a crimping tool somewhere!!.
Cheers Paul
« Reply #34 on: March 18, 2014, 11:13:39 pm »
Hi Paul,
Can you run the same test between the 2 PCs (instead of passing through the router) ? Or have you done the same test with the same results ?
« Reply #35 on: March 18, 2014, 11:19:45 pm »
Hi Alain - yea that was what I was intending to try - PC direct to PC with a short network cable just to make sure everything working properly before I start adding back in longer cable and router etc.
« Reply #36 on: March 18, 2014, 11:21:53 pm »
Hi Paul,
Maybe things will change for the better Happy
But... Be sure that your router is not the culprit, by using a cable long enough (if possible) to create the same situation...
« Reply #37 on: March 18, 2014, 11:32:31 pm »
Hi Alain,
Thanks Anthony. I am still struggling with some obstacles about having a NAS, but I certainly find that alternative interesting.
« Reply #38 on: March 25, 2014, 10:22:40 pm »
It turns out that the router was the culprit. The 1Gb label on the back only applies to one of the network ports the others are all 100Mb. With a decent Gig router in place I can transfer at close to 1Gb with Cat 5 cable - so that's good!!!
Now I don't have time to make a cup of tea while waiting for XX to start playing music.
« Reply #39 on: March 26, 2014, 02:20:21 am »
« Reply #40 on: March 26, 2014, 07:59:12 am »
If that is so you have 100mb throughput. Think about it ...
« Reply #41 on: March 26, 2014, 10:05:11 pm »
No - I have a new router now with all 1Gb ports. Before only one port was 1Gb. Anyway now data transfer measures very close to 1Gb.
« Reply #42 on: March 27, 2014, 08:03:18 am »
Anyway, now people readily understand why the connection better be direct; it just avoids lousy home routers and misunderstandings about them.
And btw, with one 1Gb ("input") port and the remainder 100Mb ("output") of course you'll still have 100Mb throughput only. That's what my previous message was about.
Also, even when all ports are rated at 1Gb it is very common that the router/switch/hub has a separate rating for total throughput. E.g. use two connections which consume 1Gb and the total throughput can be 1Gb alright, but each connection only receives 500Mb.
« Reply #43 on: March 27, 2014, 07:42:15 pm »
.............. and CAT5 wiring is no problem at a Gig although theoretically rated at 100Mb mine is a 50m run (not much in network terms) but anyway just for information.
Pages: 1 2 [3]  All
Page created in 7.229 seconds with 19 queries.
