November 22, 2024, 10:03:15 pm *
Pages: 1 [2] 3  All
Author Topic: Network Access in Minimised  (Read 44661 times)
« Reply #15 on: March 16, 2014, 01:05:44 pm »
Hi Paul,
I am trying myself to wrap my head around this... Is it related to noise ? Surely, but for the explanation...
PS: I like the last answer Peter Wink
« Reply #16 on: March 16, 2014, 09:01:53 pm »
Maybe because the OS disc can still be spinning following a transfer of files to (say) RAM Disc? - the difference in SQ between network accessed music and disc accessed is not massive but certainly worth having. It is not as big as leaving a DVD rewriter connected.
Stanray
« Reply #17 on: March 17, 2014, 11:45:35 am »
Not shure if this is the correct spot for this question  unhappy
I'm planning to add a NAS to my home network. Are there any specific requirements for a (simple) NAS, for convenient use with XXHE?
Thanks.
Stanley
« Reply #18 on: March 17, 2014, 11:49:02 am »
Stanley,
Just before you think I won't answer :
I don't know the answer. I myself always struggled with them (but last time was 2-3 years ago) and they all went back to where they came from.
Stanray
« Reply #19 on: March 17, 2014, 12:38:42 pm »
Where "on the LAN" do you get your music files from then?
Stanley
« Reply #20 on: March 17, 2014, 01:21:01 pm »
Just another PC Stanley.
Stanray
« Reply #21 on: March 17, 2014, 01:34:41 pm »
 oops Silly me, I knew that.
« Reply #22 on: March 17, 2014, 02:14:41 pm »
Haha.
« Reply #23 on: March 18, 2014, 12:01:53 am »
Thanks.
Stanley
Hi Stanley,
I assume that you will use the NAS for more than your music collection.  Personally, I have a wired network (with wireless as well for those devices with no physical connection) with a Netgear ReadyNAS Pro at its core.  Our entire DVD and Bluray collection is ripped to the NAS and can be streamed direct to the home theatre via the Denon Receiver or the AppleTV.  My music library is also entirely contained on the NAS as are the primary archives and backups from all the computers in the house.
I don't know why Peter had problems with a NAS in the past, but they are generally easy to set up and in my view indispensable.
I have used XXHE and its LAN functions to draw music directly from the NAS, but am annoyed by the wait for the network to come back up in windows, so am persisting with music on a local SSD for now.
« Reply #24 on: March 18, 2014, 07:11:46 am »
Anthony,
Same for me in Windows 7. But Windows 8 is hardly noticable.
Is slow in Windows 8 for you ?
« Reply #25 on: March 18, 2014, 10:40:01 am »
It was not quick in w8 but I think it was quicker.
I don't use w8 at the moment because that pesky "music stops then you move the mouse to get it started" problem is back.  I will have to find and trawl through that thread to see if I can get that problem to go away.
Stanray
« Reply #26 on: March 18, 2014, 12:15:07 pm »
Hi Anthony,
I would use a NAS (or alternative) primary for music for SQ with XXHE, and maybe for backup of photo's. I have no movie collection (there are cinema's at close range  good).
So I think a simple NAS or pc would do the trick, but it should work fast and easy.
Not sure what to do right now.
Stanley
« Reply #27 on: March 18, 2014, 12:28:18 pm »
Stanley,
Well, a NAS is simply an optimised computer.  It runs a motherboard with a processor (maybe a Celeron), ram (1GB or 2 GB), has a bunch of SAS or SATA ports for its collection of drives, one or two LAN ports, and would generally run Linux.  A NAS is a computer.
So if what you are after is the best thing for SQ and its use is limited, then maybe do what Peter is suggesting, although you should not need a crossover cable because modern LAN ports self detect the type of connection and can adjust themselves accordingly (so just use a normal LAN cable).
« Reply #28 on: March 18, 2014, 12:49:24 pm »
Hi Anthony,
When you used your NAS, did you need to have your drive formatted in a linux format or was it possible for you to leave it in NTFS ?
« Reply #29 on: March 18, 2014, 01:04:48 pm »
Hi Stanley, not sure if this is helpful, but I've been using a NAS for music storage for a number of years now. It's 'only' 5x1TB drives, which is enough for me, and has worked perfectly since I set it up. I'm not at home right now so can't check, but it's a Synology NAS (the 1010+, I think).
This is how I use it with my main music PC:
1. rip CD from Plextor drive (without cache) onto SSD of ripping PC
2. transfer ripped files to NAS
3. put music PC in normal non-minimized state
4. transfer files to single HDD (2TB, I think - with a 100GB partition for the OS and XX) in music PC
5. put music PC back into minimized mode
Now, with the dedicated music PC in my office system I do not transfer the files to its internal HDD (actually a small SSD), but access them directly from the NAS (with 'copy to XX drive' enabled) for playback. The waiting time for the transfer before playback is literally a matter of a few seconds - nothing at all really. But FYI, the LAN is constantly 'on' as I use remote desktop via LAN to control the dedicated music PC from my work PC on my desk. Probably not the best for SQ, but it's OK for my office system.
When I get back home, I can test using the NAS with my main PC and disabling the LAN before playback. Never tried this. Might be interesting to hear if there is much difference between playing the files from the internal HDD.
HTH.
Pages: 1 [2] 3  All
Page created in 0.109 seconds with 19 queries.
