« on: March 13, 2014, 10:47:45 am » |
I am trying to set up XX to access music on another server during playback in minimised o/s. No problem in full o/s but in minimised o/s I cannot see the server. I have the following settings
All Services Off / Keep LAN - Not Persist
With the above settings I can access the internet in minimised o/s but I cannot "see" any other servers on the network.
Help would be appreciated.
« Reply #1 on: March 13, 2014, 04:05:37 pm » |
Paul,
Look at this more rigidly; Take for the most easy/direct example a direct connection from PC to PC (this needs a crossed Ethernet cable). Now no matter how or what you need to make your drives on the "other server" shared and make them seeable in Explorer on the Audio PC. This all works on the side of XXHighEnd. Which ...
Does not mean it works with your PC knowledge etc. to set up sharable drives in the fashion needed. So this is quite another matter, and longer ago I prepared some Tutorial for it but it is not finished (and no time to do that really). Otoh, you should have done this correctly already, because you can see them in Normal OS.
Key is : You don't need anything special for "detecting" shares etc., and just using Exporer on the Audio PC is fine enough. One thing : I think it can happen (with the very first time only) that in MinOS your Network Adapter is shut off. If that is the case it only needs a "Try to solve the problem" (similar) and Windows will switch it on.
Last thing to avoid the unknown : I think I never tried it through a router etc., and that can matter. So use that direct connection to get it going.
If you think you are doing all correctly already then I don't know what the problem is, but it shouldn't be about shut off services etc. by XXHighEnd (the ones needed will stay).
Oh, did you ever assign driver letters to the shares you see on the Audio PC when in Normal OS ? That would be necessary I think ...
« Reply #2 on: March 13, 2014, 06:14:56 pm » |
Hi Peter - not sure what I did but it is working now and it is working through a router.
Before I was using a USB disc with the music files on I used to set "Copy Files to XX Directory by standard" on and I thought with that option ticked the USB link could not affect sound quality because the file would first copied to and played from (RAM) Disc and not from the USB Disc. Was I wrong?
« Reply #3 on: March 13, 2014, 06:31:26 pm » |
Paul, When a Playback Drive is used, the CopytoXX is engaged by standard. So when the Playback Drive is a RAMDisk it goes from the XX folder to the RAMDisk (all file types). But are you saying that this is related to it yes or no working ? Regards, Peter PS: And great that you have it working now of course.
« Reply #4 on: March 13, 2014, 06:47:53 pm » |
But are you saying that this is related to it yes or no working ? No not related at all. I just wanted to know if there is any SQ benefit in access files over a network compared with accessing files from a local USB disc if the "copy to..." option is in operation.
« Reply #5 on: March 13, 2014, 07:55:04 pm » |
Paul, there sure is a difference just because of the connected USB disk ... (think similar as disconnecting the CDRom and that making a difference, ok ?)
« Reply #6 on: March 13, 2014, 08:24:38 pm » |
duurrgh!!! and as I previously got rid of fans disconnected dvd drive etc to get best SQ ..... I must be turning senile!!!
Thanks
P
Jack
« Reply #7 on: March 13, 2014, 10:58:43 pm » |
If you really want to do this, why not map the network drive, then your OS should see it as a an 'inboard' drive? Not tried it but..... Best Jack
Peter's latest version & settings - Win10/64 - Octo core PC - 32gig RAM - NOS1 Mourinho Edition - BD Amps & filters - BD Inspired Horns - Comfy leather armchair with tablet remote control
« Reply #8 on: March 13, 2014, 11:11:55 pm » |
Hi Jack - no problem doing that but not sure it helps. The issue here is the time taken to copy files across - connection and access now seem reliable.
« Reply #9 on: March 14, 2014, 08:38:37 am » |
If you really want to do this, why not map the network drive, then your OS should see it as a an 'inboard' drive? Which just *is* the way to do it (tried to tell that in my other post). The issue here is the time taken to copy files across Can't be or shouldn't be. But the Playback Drive *has* to be a RAMDisk. So this is a 100% must. And a 1Gb/s network connection of course, preferrably direct (not through a router). Peter
« Reply #10 on: March 14, 2014, 10:41:21 pm » |
RAM Disk in use no problems there.
More of a problem is the bog standard 100mB Ethernet set up. The PC's are no problem they can go to 1Gb but the wiring and router is more of a problem. I will see if I can get hold of a 1Gb router and see how far the standard Cat5 wiring can be pushed.
P
« Reply #11 on: March 15, 2014, 11:01:10 am » |
P
Paul, cat5e will transfer 1gb all day every day...it does here anyway. Peter, why do you recommend direct connection instead of a router?
« Reply #12 on: March 15, 2014, 11:09:15 am » |
Anthony, Because a direct connection will be faster for the routers we (as no IT professionals) tend to use. It depends a bit on how others may "occupy" the router though. But this is only a small part of the game, because the more important is almost how a router/switch may interfere with connections and how "no router/switch" will not interfere at any time. So do notice that not all LAN services are running and that real "detection" means as such do not run. So, detecting is different from "known to be there". And thus : While people could have problems like Paul described it at first, it is better to avoid all what may interfere. So my message was merely about that rather then speed. And if then someone comes along complaining about speed, well ... (I'm in circles now ) Peter
« Reply #13 on: March 15, 2014, 10:32:12 pm » |
Paul, cat5e will transfer 1gb all day every day... If only I had cat5e!!!! - mine is just plain old cat5. Anyway from what I read on the World Wide Wonderweb it might be possible to push it significantly further than its 100mb rating. Unfortunately I cannot easily rig up a direct link (with xover cable) to my main server and my router has only one 1Gbit socket. But I may be able to set up something with a 1Gig switch that I can borrow from my mate (Dave from "down the road"). What I don't understand is why music accessed over my local network sounds better than the same music accessed on a separate partition on my OS disc. Given that the files are copied to and then access by XX from RAMDisk and the OS disc stays connected so the source of noise is always there. Or am I missing something glaringly obvious again like I did in my earlier post? Cheers Paul
« Reply #14 on: March 16, 2014, 08:01:43 am » |
Paul,
Any CAT5 will do it.
And why it sounds better ? because I say so ? (and which is why the feature is in there in the first place) haha
Regards, Peter
