November 23, 2024, 01:41:25 am *
Author Topic: 1.186a will not play with q's set to 1  (Read 10048 times)
bdohmeyer
« on: March 03, 2014, 07:16:58 pm »
I have disabled the cover art as suggested.  Now play will not start when q3,4,5=1.  I changed q3,4,5 to =3 and it is playing now. Would like to go back to 1's
Processor i7 970: 3.2GHz-3.46GHz, 6+6 cores/ W7 Ultimate 64bit SP1 / Mb Asus X58/ RAM 24GB/ OS and XXHE on Samsung 111 SSD,  WD RE4 WD5003ABYX, 500Gb, 7200rpm, 64Mb cache playback Drive, WD20EFRX Storage drive, PSUSeasonic Platinum 660 + - 2%.
XXHE 1.186a/ Metrum Hex w/ USB Hi Face module/#4 Engine/ Adaptive/ 512/ Straight Contiguous/ PP:Low/ TP:Real Time/ Clock Res. 1ms/ Allow Ph. Alig.:Off/ HDCD:On/ ALL Services Off/ SFS:120 Unattended/ Minimize OS/ Peak Extend: On/ IPhase Off/ ArcPredict/ fx:On. Output x 4/ Q1=6, Q31,Q41,Q51. xQ1=10
Preamp:XX.  (Hex Straight to Amp). Amp:AR Ref 150 (Sovtek KT120s),
Coincident Total Victory II (96dB 1m@1 watt)
« Reply #1 on: March 03, 2014, 07:40:16 pm »
Huh ?
So when Coverart is disabled it holds back playback ?
Odd.
You can set Wallpaper Coverart not to show; you can also disable it all together ("Don't do anything with Coverart").
Does this make a difference ?
bdohmeyer
« Reply #2 on: March 03, 2014, 08:18:29 pm »
Just disabled cover art to "do nothing"  Yes - when qs all set to 1 nothing starts.
bdohmeyer
« Reply #3 on: March 03, 2014, 08:51:16 pm »
I was reading about q1 and it seems to = importance with buffer size.  I had to experiment with old XX version with my KS Hi face usb module and 768 seemed to work ok.  I'm not positive that is correct.
bdohmeyer
« Reply #4 on: March 03, 2014, 09:12:35 pm »
I just set all my settings to = Juan
q1=6, q1X=10, q3,4,5=1, clock 1ms and sfs = 120
Everything works! (even with cover art)
Page created in 0.115 seconds with 19 queries.
