April 17, 2025, 03:42:33 pm *
Author Topic: "Unable to clear Proxy"  (Read 7919 times)
bdohmeyer
« on: March 03, 2014, 04:38:24 pm »
I just changed my q5 to zero to avoid the cover art error.  At the end of the first track XX stopped "Unable to clear proxy....."
I had to restart the computer to play anything.
Processor i7 970: 3.2GHz-3.46GHz, 6+6 cores/ W7 Ultimate 64bit SP1 / Mb Asus X58/ RAM 24GB/ OS and XXHE on Samsung 111 SSD,  WD RE4 WD5003ABYX, 500Gb, 7200rpm, 64Mb cache playback Drive, WD20EFRX Storage drive, PSUSeasonic Platinum 660 + - 2%.
XXHE 1.186a/ Metrum Hex w/ USB Hi Face module/#4 Engine/ Adaptive/ 512/ Straight Contiguous/ PP:Low/ TP:Real Time/ Clock Res. 1ms/ Allow Ph. Alig.:Off/ HDCD:On/ ALL Services Off/ SFS:120 Unattended/ Minimize OS/ Peak Extend: On/ IPhase Off/ ArcPredict/ fx:On. Output x 4/ Q1=6, Q31,Q41,Q51. xQ1=10
Preamp:XX.  (Hex Straight to Amp). Amp:AR Ref 150 (Sovtek KT120s),
Coincident Total Victory II (96dB 1m@1 watt)
« Reply #1 on: March 03, 2014, 04:49:49 pm »
What is your Playback Drive ?
If that wasn't filled in (in Settings) it will be your XX folder.
bdohmeyer
« Reply #2 on: March 03, 2014, 05:22:09 pm »
Hi Peter - playback drive = WD RE4 WD5003ABYX, 500Gb
This was set in settings
« Reply #3 on: March 03, 2014, 06:23:13 pm »
Ok, thanks.
If this happens again try to recall whether something went odd/wrong in advance of it. So this is just about a file which stays in use and what should not be. I have seen it once or twice myself.
bdohmeyer
« Reply #4 on: March 03, 2014, 08:20:19 pm »
Just received another unable to clear proxy error after disabling cover art.  qs not = 1
Page created in 9.331 seconds with 19 queries.
