November 23, 2024, 11:46:16 am *
Author Topic: P.A. Schemes behave different at relative changes ?  (Read 25091 times)
« Reply #15 on: November 29, 2007, 08:24:07 pm »
Okay, I will try that. But ... this is what you told in the first post :
Correct me if i am wrong but i think the schema's react  different when you start your pc and first play No appointment. Then go to schema 3
which is different from going immediately to Scheme-3 right after a reboot as you said in your last post (first dutch sentence).
I will try that now ...
« Reply #16 on: November 29, 2007, 08:34:26 pm »
Well there i was wrong but in this post...
I think i found it..... Sometime's the schema's will hang (or something)... the first pic is the one after reboot the pc and direct play 3.... i did random affinity and it shows 2 core's
The second pic is also playing schema 3 but than when i was on schema 1 first... or did some switching between them.... now random affinity and it shows 1 core.
But never mind it is difficult enough....
« Reply #17 on: November 29, 2007, 08:38:06 pm »
It is Gerard ... but thanks to your now accurate outlay I can copy that behaviour (and it's not even difficult).
Hmm ...
oops
« Reply #18 on: November 29, 2007, 08:41:39 pm »
Hmm ...
oops
 heat really thought i was getting crazy... haha  Happy
« Reply #19 on: November 29, 2007, 09:26:19 pm »
It even looks like it doesnt go back to 3 and No Appointment at all.... When i push stop, No appointment, play
Affinity shows one core....
So what we have been testing could be very wrong... (Sometime's) because there was a time that it changed...
EDIT: Even when i shut XX down it come's back to 1 core....
EDIT: Well it really looks like that the STOP before the other things really helps... If not it stays ( I think ) at core 1.
« Reply #20 on: November 29, 2007, 10:46:05 pm »
And I was just thinking I tested it all so excessivley. Self learning Vista ? nea
Must be caused by me somehow.
wacko
« Reply #21 on: November 30, 2007, 07:21:12 pm »
Phwew ... solved.
Until I upload a next version you can only be sure that all is doing what you intended when right after a reboot the Scheme is selected once before Play.
The reset (e.g. after Stop) is not okay, but I don't think you care.
What it comes to : don't change Schemes during a (boot) session after you played already.
« Reply #22 on: November 30, 2007, 07:36:37 pm »
 good good good
